查看: 2127|回复: 1
[求助]请教怎样把多段线只保留选择时选取的一段其余的删掉 。
发表于 2006-7-4 09:31:00 | 显示全部楼层 |阅读模式
发表于 2022-12-8 10:49:24 | 显示全部楼层
(defun c:xysbl (/  co getco i s s0 s1 ss ss1)
        ;;多选颜色保留
  (defun GetCo (s0 / a co en la)
    (setq en (entget s0))
    (if  (setq a (assoc 62 en))
      (cdr a)
      (cdr (assoc 62 (tblsearch "layer" (cdr (assoc 8 en)))))
        (if (and (progn (princ "\n多选过滤颜色对象:")
                                           (setq s0 (ssget ))
                                (setq s0 (mapcar 'GetCo (vl-remove-if 'listp (mapcar 'cadr (ssnamex s0)))))
                                        (princ "\n选择目标对象:")
                                        (setq s (ssget))
                                (setq s (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
                                (setq s (mapcar '(lambda(x)(list x (GetCo x)))s))
                                (setq s (vl-remove-if-not '(lambda(x)(member (cadr x) s0))s))
                                (setq s (mapcar 'car s))
                                (setq ss (ssadd))
                                (progn (foreach x s (ssadd x ss)) t)
                        (sssetfirst nil ss)
                        (princ (strcat "\n已选择" (itoa (sslength ss)) "个对象"))
                        (command "erase" (ssget "a") "r" ss "")
GMT+8, 2025-11-16 05:20 , Processed in 0.139972 second(s), 23 queries , Gzip On.
