查看: 1625|回复: 3
[求助]字符个数计数
发表于 2006-7-17 19:14:00 | 显示全部楼层 |阅读模式
现在想一次先输出T的数量,然后输出R的数量,请问该怎么改?
 Sub co()
    Dim SSet As AcadSelectionSet
    Dim obj As AcadText
    Dim ptcen(0 To 2) As Double
    Dim endPoint1(0 To 2) As Double
    Dim endPoint2(0 To 2) As Double
    Dim cline As AcadLine
    Dim lineHalfLength As Double
    Dim groupCode(0 To 4) As Integer
    Dim dataValue(0 To 4) As Variant
    Dim i As Integer
    On Error Resume Next
    If Not IsNull(ThisDrawing.SelectionSets.Item("tex")) Then
       Set SSet = ThisDrawing.SelectionSets.Item("tex")
       SSet.Delete
    End If
    Set SSet = ThisDrawing.SelectionSets.Add("ArcsCirclesEllipses")
    '设置选择过滤器
    groupCode(0) = -4
    dataValue(0) = "<or"
    groupCode(1) = 0
    dataValue(1) = "0"
    groupCode(2) = 0
    dataValue(2) = "text"
    groupCode(3) = 0
    dataValue(3) = "0"
    groupCode(4) = -4
    dataValue(4) = "or>"
    '提示用户选择
    ThisDrawing.Utility.Prompt "选择" & vbCr
    SSet.SelectOnScreen groupCode, dataValue
    For Each obj In SSet
    If obj.TextString = "T" Then
    i = i + 1
    End If
    obj.Update
    MsgBox "共有T" & i
   If obj.TextString = "R" Then
    i = i + 1
    End If
    obj.Update
    MsgBox "共有R" & i
    Next obj
End Sub
发表于 2006-7-18 12:33:00 | 显示全部楼层
你能解释下下这里是什么意思么?
groupCode(1) = 0
dataValue(1) = "0"
 楼主| 发表于 2006-7-21 21:46:00 | 显示全部楼层
groupCode(1) = 0
dataValue(1) = "0"
是原过滤器过滤多种数据!
发表于 2006-7-21 23:58:00 | 显示全部楼层
没有这种做法:)
groupCode数组表示DXF组码
dataValue数组表示对应组码的数值
组码0表示一个实体的图元类型
关于这些具体可以看看DXF组码的帮助部分
好像上次做过一次的
设置过滤器为
0,"Text",1,"T"
就可以过滤出T的数量
GMT+8, 2025-5-4 10:41 , Processed in 0.157497 second(s), 23 queries , Gzip On.
