查看: 1687|回复: 1
历遍多个布局求助
发表于 2006-8-2 15:52:00 | 显示全部楼层 |阅读模式
Option Explicit
Private Sub CommandButton1_Click()
Dim layo As AcadLayout
Dim sset As AcadSelectionSet
Dim str1 As String
Dim oldstr As String
Dim newstr As String
Dim ftype(0) As Integer
Dim fdata(0) As Variant
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
Dim i As Integer
Dim abc As Object
ftype(0) = 0
fdata(0) = "TEXT"
oldstr = "a"
newstr = "e"
point1(0) = 343
point1(1) = 272.5
point1(2) = 0
point2(0) = 403
point2(1) = 280
point2(2) = 0
UserForm1.Hide
'以下建立选择集
On Error Resume Next
   If Not IsNull(ThisDrawing.SelectionSets.Item("ss1")) Then
      Set sset = ThisDrawing.SelectionSets.Item("ss1")
      sset.Delete
   End If
    Set sset = ThisDrawing.SelectionSets.Add("ss1")
    sset.Clear
'选择集建立完毕
'%%%%%%%%%%%%%%%%%之间的部分有问题
For i = 0 To ThisDrawing.Layouts.Count - 1 Step 1
Set abc = ThisDrawing.Layouts.Item(0)
    sset.Clear
    sset.Select acSelectionSetWindow, point1, point2, ftype, fdata
    str1 = sset.Item(0).TextString
    If InStr(str1, oldstr) Then
       sset.Item(0).TextString = replacestr(str1, oldstr, newstr, False)'调用下面函数
       'sset.Item(0).Update
       ThisDrawing.Regen acAllViewports
    End If
  Next i
'%%%%%%%%%%%%%%%%%%%%%以上有问题
End Sub
'以下函数执行替换==========================================================================
Public Function replacestr(ByVal searchstr As String, ByVal oldstr As String, ByVal newstr As String, ByVal firstonly As Boolean) As String
If searchstr = "" Then Exit Function
If oldstr = "" Then Exit Function
Dim i As Integer, oldstrlen As Integer, holdstr As String, strloc As Integer
replacestr = ""
oldstrlen = Len(oldstr)
strloc = InStr(searchstr, oldstr)
While strloc > 0
      holdstr = holdstr & Left(searchstr, strloc - 1) & newstr
      searchstr = Mid(searchstr, strloc + oldstrlen)
      If firstonly Then replacestr = holdstr & searchstr: Exit Function
Wend
End Function
图形有2个布局,在每个布局中,在(343,272.5)与(403,280)范围内有一个text:内容为"hah",我想把他变成"heh",可是上面的程序只能对当前显示的布局有效,对其他布局没作用不知道为什么,麻烦各位给看看吧
发表于 2006-8-2 19:08:00 | 显示全部楼层
 ThisDrawing.SetVariable "CTAB", Layout.Name
加上这一句,使他变成当前布局.
GMT+8, 2025-5-3 19:07 , Processed in 0.167378 second(s), 24 queries , Gzip On.
