查看: 1795|回复: 4
程序运行后产生的问题
发表于 2006-8-7 12:34:00 | 显示全部楼层 |阅读模式
最近变了一个程序,如下:
Private Sub CommandButton2_Click()
Dim pt As Variant
Dim textobject As AcadText
Dim pt1 As Variant
Dim pt2 As Variant
Dim pt3 As Variant
Dim pt4 As Variant
Dim pt5 As Variant
Dim pt6 As Variant
Dim pt7 As Variant
frmMain.Hide
pt = ThisDrawing.Utility.GetPoint(, "请输入插入点!")
pt1(0) = pt(0) + 488: pt1(1) = pt(0) - 884
pt2(0) = pt(0) + 5002: pt2(1) = pt(0) - 890
pt3(0) = pt(0) + 9148: pt3(1) = pt(0) - 752
pt4(0) = pt(0) + 9189: pt4(1) = pt(0) - 1250
pt5(0) = pt(0) + 23067: pt5(1) = pt(0) - 884
pt6(0) = pt(0) + 24475: pt6(1) = pt(0) - 984
pt7(0) = pt(0) + 9138: pt7(1) = pt(0) - 965
Set textobject = ThisDrawing.ModelSpace.AddText("sfsf", pt1, 500)
End Sub
程序运行到pt1(0) = pt(0) + 488: pt1(1) = pt(0) - 884
调试错误,提示类型不匹配!请问是什么原因?另,在输入汉字时怎么规定字体?谢谢!
发表于 2006-8-7 14:23:00 | 显示全部楼层
Dim pt As Variant
Dim pt1(2) As Double
pt1(0) = pt(0) + 488: pt1(1) = pt(0) - 884: pt1(2) = 0
 楼主| 发表于 2006-8-8 12:24:00 | 显示全部楼层
谢谢!顺便请问一下怎样为输入的汉字设置字体?
发表于 2006-8-9 22:06:00 | 显示全部楼层
你搜索一下吧,很多的
 楼主| 发表于 2006-8-10 19:16:00 | 显示全部楼层
找到了一个,如下:
set ts = ThisDrawing.ActiveTextStyle
tsna = ts.fontFile
    Set ts1 = ThisDrawing.ActiveTextStyle
    ts1.fontFile = "HZTXT"
ThisDrawing.ActiveTextStyle = ts1
Set textobject = ThisDrawing.ModelSpace.AddText("汉字",pt5, 500)
ThisDrawing.Regen acActiveViewport
ts.fontFile = tsna
确实程序执行时,我采用MSGBOX看字体,气体确实由原来的ROMANS 便成了HZTXT,然后写入"汉字"两个字,之后又变成了原来的ROMANS。但是当我在查看CAD中"汉字"两个字的字体时,却是ROMANS。不知道为什么,请指教!
GMT+8, 2025-7-1 06:06 , Processed in 0.158021 second(s), 23 queries , Gzip On.
