查看: 2731|回复: 5
[求助]如何把从一个文件中的部分对象拷贝到另一个文件中(解决了)
发表于 2006-8-9 19:09:00 | 显示全部楼层 |阅读模式
()如何把从一个文件中的部分对象拷贝到另一个文件中
不知道用哪个命令啊.
建了个选择集,好像用copybojects不行啊.
Dim doc1 As AcadDocument
Set doc1 = acadApp.Documents(acadApp.ActiveDocument.Name)
Dim doc2 As AcadDocument
Set doc2 = acadApp.Documents.Add("acaddocument")
doc1.CopyObjects appendobjs, doc2.ModelSpace
调用CopyObjects的文档,必须是包含appendobjs的文档。
发表于 2006-8-9 21:54:00 | 显示全部楼层
怎么不行?看看你的代码
 楼主| 发表于 2006-8-10 08:06:00 | 显示全部楼层
 Dim FilterType(1) As Integer
   Dim FilterData(1) As Variant
   Set sjx = ThisDrawing.SelectionSets.Add("sjx")
   FilterType(0) = 2
   FilterData(0) = "TK" '是圆
   'FilterType(1) = 62
   'FilterData(1) = 10  '颜色是3
   FilterType(1) = 8
   FilterData(1) = "0"  '图层是0
   Dim mode As Integer
 mode = acSelectionSetAll
 'sjx.Select mode, , , FilterType, FilterData
  sjx.SelectOnScreen FilterType, FilterData '选择设计线
    Dim newvarAttributes, inpoint, entry1 As Variant
    Dim ss, sss, ssss As String
    Dim sjxcount As Integer
    sjxcount = sjx.Count
     Dim templateFileName As String
   Dim DOC1 As AcadDocument
    ReDim objects(sjxcount) As AcadEntity
     Dim retObjects As Variant
        i = 0
     For Each entry In sjx
   Set objects(i) = entry
    i = i + 1
     Next entry
     Set DOC1 = Documents.Add
     retObjects = ThisDrawing.CopyObjects(objects) '这里出错啊
MsgBox "1"
 ThisDrawing.Application.ZoomAll
发表于 2006-8-10 08:39:00 | 显示全部楼层
sjxcount = sjx.Count-1
ReDim objects(sjxcount-1) As AcadEntity
 楼主| 发表于 2006-8-10 11:22:00 | 显示全部楼层
 改了这里还是出错啊
GMT+8, 2025-5-3 19:52 , Processed in 0.190276 second(s), 29 queries , Gzip On.
