查看: 1608|回复: 3
选择集中的点转成数组后出现的问题?
发表于 2006-8-12 08:30:00 | 显示全部楼层 |阅读模式
选择集中的点转成数组后出现的问题?源程序如下:
Sub mm()
  On Error Resume Next
   Dim sset As AcadSelectionSet
    Dim objcir As AcadCircle
    Dim radius As Double
    Dim filtertype(0) As Integer
    Dim filterdata(0) As Variant
    If Not IsNull(ThisDrawing.SelectionSets.Item("Circles")) Then
       Set sset = ThisDrawing.SelectionSets.Item("Circles")
       sset.Delete
    End If
    Set sset = ThisDrawing.SelectionSets.Add("Circles")
    filtertype(0) = 0 '设置选择过滤器
    filterdata(0) = "circle"
    sset.SelectOnScreen filtertype, filterdata
     Dim ptarr()
    Dim count As Integer
    count = sset.count
    ReDim ptarr(count - 1)
     For Each objcir In sset
     Dim ptcen As Variant
     ptcen = objcir.Center
     Dim i As Integer
     For i = 0 To count - 1
     Dim cir1 As AcadCircle
     Set cir1 = sset.Item(i)
     cir1.Center = ptarr(i)
     Next i
     Next
    Dim pt1 As Variant
    pt1 = ptarr(0)
    MsgBox pt1(0)
    MsgBox pt1(1)
End Sub
运行后无任何反应!
发表于 2006-8-12 09:24:00 | 显示全部楼层
ReDim ptarr(count - 1,2)
dim ii,i as Integer
ii=0
i=0
    ' ptcen = objcir.Center
  Set ptcen = objcir.Center
     For i = 0 To 2
ptarr(ii,i)=ptcen(i)
         Next i
ii=ii+1
     Next
改成这样试试
 楼主| 发表于 2006-8-12 17:37:00 | 显示全部楼层
先谢谢!
还是不行
Dim x As Double
 Dim y As Double
 x = ptarr(0, 0)
 y = ptarr(0, 1)
    MsgBox x
    MsgBox y
任何时候显示为0,0
发表于 2006-8-12 18:28:00 | 显示全部楼层
  1. ReDim ptarr(sset.count - 1)
  2. For i= 0 to sset.count-1
  3.      ptarr(i)=sset(i).Center
  4. Next
  5. msgbox ptarr(0)(0) & "," & ptarr(0)(1) & "," & ptarr(0)(2)
GMT+8, 2025-5-3 18:19 , Processed in 0.148961 second(s), 24 queries , Gzip On.
