查看: 1786|回复: 2
[VBA][求助]关于选择时如何出现矩形框
发表于 2006-8-14 21:10:00 | 显示全部楼层 |阅读模式
请问,如何用vba在选择对象时,出现矩形框?
就像这个代码一样,获取距离时,可以出现一根直线。
dim Weizhi1(0 to 2) as Double, varRet  As Variant,Henjuli as Double
varRet = ThisDrawing.Utility.GetPoint(, "获取图框左上角坐标点") '==获取边框左上角
    Weizhi1(0) = varRet(0)
    Weizhi1(1) = varRet(1)
    Weizhi1(2) = varRet(2)
Henjuli= ThisDrawing.Utility.GetDistance(Weizhi1, "边框长度")
发表于 2006-8-15 08:17:00 | 显示全部楼层
MySet.Select acSelectionWindow, P1, P2, FilterType, FilterData
发表于 2006-8-15 09:00:00 | 显示全部楼层
[WEB]http://www.mccad.net/object/acad2004/idh_selectonscreen.htm[/WEB]
GMT+8, 2025-5-3 20:22 , Processed in 0.228482 second(s), 23 queries , Gzip On.
