查看: 1269|回复: 2
看看下面的阵列所选文本的代码错在那里?
发表于 2006-8-16 17:11:00 | 显示全部楼层 |阅读模式
        Dim TextSSet As AcadSelectionSet
        ThisDrawing.Utility.Prompt vbCr & "选择单行文字:"
        TextSSet.SelectOnScreen
        Dim RetVal As Variant
        RetVal = TextSSet.ArrayRectangular(4, 4, 1, 10, 10, 1)
运行后报什么:运行时错误'91',对象变量或with块变量未设置.
发表于 2006-8-16 18:41:00 | 显示全部楼层
On Error Resume Next
ThisDrawing.SelectionSets.Item("TextSSet ").Delete
 Set TextSSet = ThisDrawing.SelectionSets.Add("TextSSet ")
发表于 2006-8-17 10:07:00 | 显示全部楼层
选择集没有ArrayRectangular方法!
GMT+8, 2025-5-3 16:41 , Processed in 0.167729 second(s), 23 queries , Gzip On.
