查看: 1305|回复: 1
求高手指点
发表于 2006-8-17 17:18:00 | 显示全部楼层 |阅读模式
这是我的一个读取sql里数据的vb,库里有很多条记录的,我怎么只能读出其中的第一条记录呀?高手们帮我看看吧!
Private Sub hb_Click()
Dim ysjlj As New ADODB.Connection
Dim ygg01 As New ADODB.Recordset
Dim xsjlj As New ADODB.Connection
Dim xgg01 As New ADODB.Recordset
Dim ygg1, xgg1 As String
Dim yljzfc, xljzfc, ysj, xsj As String '源新数据库连接字符串
yljzfc = "provider=sqloledb.1;password=" & yyhmm.Text & ";persist security info=true;user id=" & yyhm.Text & ";initial catalog=" & ysjk.Text & " ;data source=" & yfwq.Text & ""
ysjlj.Open yljzfc '连接源数据库
xljzfc = "provider=sqloledb.1;password=" & xyhmm.Text & ";persist security info=true;user id=" & xyhm.Text & ";initial catalog=" & xsjk.Text & " ;data source=" & xfwq.Text & ""
xsjlj.Open xljzfc '连接源数据库
'xsj = " select * into gg1 from gg01 where ga01='1'"
'xgg01.Open xsj, xsjlj, adOpenKeyset, adLockPessimistic '在新数据库中新建gg1表
'xgg01.Close
'下面将源数据库中gg01表的内容导入到gg1表中。
ysj = "select *from gg01 where ga033='114'"
ygg01.Open ysj, ysjlj, adOpenKeyset, adLockPessimistic
xsj = "select * from gg1"
i = 0
If Not ygg01.EOF Then
i = i + 1
 xgg01.AddNew
 xgg01.Fields("ga01") = ygg01.Fields("ga01")
 xgg01.Fields("ga18") = ygg01.Fields("ga18")
 xgg01.Fields("ga03") = ygg01.Fields("ga03")
 xgg01.Fields("ga04") = ygg01.Fields("ga04")
'xgg01.Update
 'Print ygg01.Fields("ga18")
 ygg01.MoveNext
 xgg01.MoveNext
Else
 'ygg01.Close
 'xgg01.Close
  'Exit Sub
End If
 rint i
;我的i值怎么都是1,可是我的库里有很多行的.
发表于 2006-8-17 18:23:00 | 显示全部楼层
Do While Not ygg01.EOF
Loop
GMT+8, 2025-5-3 17:32 , Processed in 0.167330 second(s), 23 queries , Gzip On.
