查看: 1900|回复: 3
龙大侠请关注~
发表于 2003-3-23 09:05:00 | 显示全部楼层 |阅读模式
不知龙大侠关于循环选择程序和透视程序的嵌套可有进展,,小弟实是一时难以实现,还请赐教,谢谢了!
发表于 2003-3-24 08:05:00 | 显示全部楼层
再试试!!只处理"polyline,line,lwpolyline,3dface,region"直线,含ARC的线不处理
再试试!! 只处理"polyline,line,lwpolyline,3dface,region"直线,含ARC的线不处理
;;注意:只处理"polyline,line,lwpolyline,3dface,region"直线,含ARC的线不处理
(defun C:TT (/ SS SS1 N N1 NN ENT CHECK TMP PT_LIST)
  (defun DO_IT (TMP)
    (if
      (and
        (not (equal (car TMP) (cadr TMP)))
        (= (vl-position TMP PT_LIST) NIL)
        (= (vl-position (list (cadr TMP) (car TMP)) PT_LIST) NIL)
       (setq PT_LIST (append PT_LIST (list TMP)))
  (defun DO_IT1        (ENT / TMP)
    (setq TMP (list (cdr (assoc 10 ENT))
                    (cdr (assoc 11 ENT))
    (DO_IT TMP)
  (setq SS (ssget '((0 . "polyline,line,lwpolyline,3dface,region"))))
  (setq PT_LIST '())
  (setq N 0)
  (repeat (sslength SS)
    (setq ENT (ssname SS N))
    (setq CHECK (cdr (assoc 100 (reverse (entget ENT)))))
    (cond
      ((or (= CHECK "AcDbPolygonMesh") (= CHECK "AcDbFace"))
       (if (= CHECK "AcDbPolygonMesh")
           (command "_.COPY" ENT "" "0,0" "@")
           (command "_.EXPLODE" (entlast))
           (setq SS1 (ssget ""))
         (progn (setq SS1 (ssadd)) (ssadd ENT SS1))
       (setq N1 0)
       (repeat (sslength SS1)
         (setq ENT (entget (ssname SS1 N1)))
         (setq NN 0)
         (setq LINE0 (list (cdr (assoc 10 ENT))
               LINE1 (list (cdr (assoc 11 ENT))
                           (cdr (assoc 12 ENT))
               LINE2 (list (cdr (assoc 12 ENT))
                           (cdr (assoc 13 ENT))
               LINE3 (list (cdr (assoc 13 ENT))
         (repeat 4
           (setq TMP (eval (read (strcat "LINE" (rtos NN)))))
           (DO_IT TMP)
           (setq NN (1+ NN))
         (setq N1 (1+ N1))
       (command "_.ERASE" SS1 "")
      ((or (= CHECK "AcDb3dPolyline")
           (= CHECK "AcDb2dPolyline")
           (= CHECK "AcDbPolyline")
           (= CHECK "AcDbModelerGeometry")
       (setq N1 0)
         (setq ENT (ssname SS1 N1))
         (DO_IT1 (entget ENT))
         (setq N1 (1+ N1))
      (t
    (setq N (1+ N))
  ;(command "_.ERASE" SS "")
  PT_LIST
 楼主| 发表于 2003-3-24 16:37:00 | 显示全部楼层
好的,多谢大侠,我再试试。
 楼主| 发表于 2003-3-25 16:47:00 | 显示全部楼层
非常感谢龙龙仔大侠,可以了,我从你返回的PT_LIST表中很方便地得到了所需的顶点坐
非常感谢龙龙仔大侠,可以了,我从你返回的PT_LIST表中很方便地得到了所需的顶点坐标。[br]
GMT+8, 2025-5-17 03:18 , Processed in 0.174687 second(s), 25 queries , Gzip On.
