- 积分
- 24588
- 明经币
- 个
- 注册时间
- 2004-3-17
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2006-8-19 13:43:00
显示全部楼层
字典和Xdata是两回事,下面的函数是向字典读写的 - Public Function SetXRecord(ByVal DictName As String, ByVal Keyword As String, ByVal XRecordData)
- Dim pDict As AcadDictionary
- Dim pXRecord As AcadXRecord
- Dim XRecordType() As Integer
- Dim pLen As Integer
- Set pDict = ThisDrawing.Dictionaries.Add(DictName)
- Set pXRecord = pDict.AddXRecord(Keyword)
- pLen = UBound(XRecordData)
- ReDim XRecordType(pLen) As Integer
- For i = 0 To pLen
- Select Case VarType(XRecordData(i))
- Case vbInteger, vbLong
- XRecordType(i) = 70
- Case vbSingle, vbDouble
- XRecordType(i) = 40
- Case vbString
- XRecordType(i) = 1
- End Select
- Next i
- pXRecord.SetXRecordData XRecordType, XRecordData
- End Function
- Public Function GetXRecord(ByVal DictName As String, ByVal Keyword As String)
- On Error GoTo ErrHandle
- Dim xt
- Set pDict = ThisDrawing.Dictionaries(DictName)
- Set pXRecord = pDict.GetObject(Keyword)
- pXRecord.GetXRecordData xt, GetXRecord
- Exit Function
- ErrHandle:
- GetXRecord = Null
- End Function
- Public Function CreateArray(ByVal TypeName As VbVarType, ParamArray ValArray())
- Dim nCount As Integer
- Dim i
- Dim mArray
- nCount = UBound(ValArray)
- Select Case TypeName
- Case vbDouble
- Dim dArray() As Double
- ReDim dArray(nCount)
- For i = 0 To nCount
- dArray(i) = ValArray(i)
- Next i
- CreateArray = dArray
- Case vbInteger
- Dim nArray() As Integer
- ReDim nArray(nCount)
- nArray(i) = ValArray(i)
- Next i
- CreateArray = nArray
- Case vbString
- Dim sArray() As String
- ReDim sArray(nCount)
- sArray(i) = ValArray(i)
- Next i
- CreateArray = sArray
- Case vbVariant
- Dim vArray()
- ReDim vArray(nCount)
- vArray(i) = ValArray(i)
- Next i
- CreateArray = vArray
- Case vbObject
- Dim oArray() As Object
- ReDim oArray(nCount)
- Set oArray(i) = ValArray(i)
- Next i
- CreateArray = oArray
- End Select
- End Function
例子 - Sub tt()
- Dim arr1(2) As Variant
- SetXRecord "tlscad", "A", Array(1, 2, "A")
- SetXRecord "tlscad", "B", Array(3, 4, "B")
- a = GetXRecord("tlscad", "A")
- If Not IsNull(a) Then MsgBox a(2)
- End Sub
