查看: 1634|回复: 3
能否告诉我如何框选屏幕上的一个块,不选其他,谢谢
发表于 2006-8-19 15:52:00 | 显示全部楼层 |阅读模式
发表于 2006-8-19 21:20:00 | 显示全部楼层
dim ft(0) as integer
dim dt(0) as variant
ft(0)=0
dt(0)="insert"
再用选择集选择就可以了
发表于 2006-8-20 22:10:00 | 显示全部楼层
Sub CadBlock()
    Dim tempBlock As Variant
    Dim msg As String
    Dim SsetObj As AcadSelectionSet
    Dim FilterType(0) As Integer, filterDate(0) As Variant
      FilterType(0) = 0
      filterDate(0) = "insert"
     Do While ThisDrawing.SelectionSets.Count > 0 '=====安全创建选择集
         ThisDrawing.SelectionSets.Item(0).Delete
     Loop
       Set SsetObj = ThisDrawing.SelectionSets.Add("CadBlock")
       SsetObj.SelectOnScreen FilterType, filterDate
     For Each tempBlock In SsetObj
       msg = tempBlock.Name
       MsgBox msg
     Next tempBlock
       SsetObj.Delete
End Sub
 楼主| 发表于 2006-8-21 08:09:00 | 显示全部楼层
非常感谢
GMT+8, 2025-5-3 20:20 , Processed in 0.179906 second(s), 23 queries , Gzip On.
