查看: 2398|回复: 1
二次开发教程例子:VB进行修剪(trim)的问题
发表于 2006-8-22 20:59:00 | 显示全部楼层 |阅读模式
 vb6的程序过程:已经画了几个圆,现在画条直线,然后作该直线的偏移阵列,最后用sendcommand命令修剪圆外的直线,只留圆内的直线。
问题:见附件,无论怎么改程序,蓝色虚线的部分无法剪切掉。圆的下部的也剪切不掉。请高手指点。cad2002图
Dim Copyline As AcadLine
    Dim spoint(0 To 2) As Double, epoint(0 To 2) As Double
    Dim Rectangularline() As Object
    dim i as integer
            spoint(0) = -3 * hjw / 2: spoint(1) = R: spoint(2) = 0
            epoint(0) = -3 * hjw / 2: epoint(1) = -R: epoint(2) = 0
    Set Copyline = AcadDoc.ModelSpace.AddLine(spoint, epoint)
NumberOfRows = 1: NumberOfColumns = 0.5 * (hjks + 1) + 2: NumberOfLevels =1
DistBetweenRows = 1: DistBetweenColumns = hjw: DistBetweenLevels = 0
Rectangularline = Copyline.ArrayRectangular(NumberOfRows, NumberOfColumns,  NumberOfLevels, DistBetweenRows, DistBetweenColumns, DistBetweenLevels)
For i = LBound(Rectangularline, 1) To UBound(Rectangularline, 1)  '阵列产生对象数组
Rectangularline(i).Layer = "主体"
Next i
     Dim det1 As String
 Dim det2 As String'不希望与cad互动,直接自己画图,剪切。
 det1 = axEnt2lspEnt(objcir2)'objcir2是个圆
 det2 = GetDoubleEntTable(Rectangularline(i), Rectangularline(i).StartPoint)
AcadDoc.SendCommand "_trim" & vbCr & det1 & vbCr & vbCr & det2 & vbCr & vbCr
Next i
以下是子函数:是AutoCAD vba 二次开发教程上的。
Public Function GetDoubleEntTable(ByVal entObj As Object, ByVal Pnt As Variant) As String
 Dim entHandle As String
 entHandle = entObj.Handle
 GetDoubleEntTable = "(list(handent " & Chr(34) & entHandle & Chr(34) & _
                     ")(list " & Str(Pnt(0)) & Str(Pnt(1)) & Str(Pnt(2)) & "))"
End Function
Public Function axEnt2lspEnt(ByVal entObj As Object) As String
    axEnt2lspEnt = "(handent " & Chr(34) & entHandle & Chr(34) & ")"
End Function
 楼主| 发表于 2006-8-23 10:22:00 | 显示全部楼层
那位大虾给看看阿。谢谢了。
GMT+8, 2025-5-3 20:14 , Processed in 0.248171 second(s), 24 queries , Gzip On.
