查看: 3083|回复: 6
用兩點坐標求線的角度!如果實現!
发表于 2006-8-31 10:19:00 | 显示全部楼层 |阅读模式
用两点坐标求线的角度!如果实现!
发表于 2006-9-1 08:03:00 | 显示全部楼层
你可以先将两点连成直线,再查询直线.angle属性
发表于 2006-9-1 09:25:00 | 显示全部楼层
Public Function CalculateLineAngle(ByVal vStartPoint As Variant, ByVal vEndPoint As Variant) As Double
  On Error Resume Next
  Dim X As Double
  Dim Y As Double
  X = vEndPoint(0) - vStartPoint(0)
  Y = vEndPoint(1) - vStartPoint(1)
  If (X > 0 And Y > 0) Or (X > 0 And Y < 0) Then CalculateLineAngle = Atn(Y / X)
  If (X < 0 And Y > 0) Or (X < 0 And Y < 0) Then CalculateLineAngle = PI + Atn(Y / X)
  If X = 0 Then
    If Y < 0 Then CalculateLineAngle = -PI / 2
    If Y > 0 Then CalculateLineAngle = PI / 2
  End If
  If Y = 0 Then
    If X < 0 Then CalculateLineAngle = PI
    If X > 0 Then CalculateLineAngle = 0
  End If
  If Abs(CalculateLineAngle - 0) < dbJudgeAngle Then CalculateLineAngle = 0
  If CalculateLineAngle < 0 Then CalculateLineAngle = 2 * PI + CalculateLineAngle
End Function
发表于 2006-9-1 09:27:00 | 显示全部楼层
还有dbJudgeAngle是我定义的常量
const dbJudgeAngle=0.001
 楼主| 发表于 2006-9-1 12:51:00 | 显示全部楼层
谢谢各位!!!呵~~
发表于 2013-4-24 10:44:50 | 显示全部楼层
二楼方法直接,三楼是求Y/X正切值再反正切
发表于 2013-4-24 19:54:52 | 显示全部楼层
这函数很有用!
GMT+8, 2025-4-29 09:23 , Processed in 0.178168 second(s), 23 queries , Gzip On.
