新手,写的有点乱
本程序可以批量修改图块比例,和旋转角度,都时相对于图块本身的角度和比例哦
;;;仅用于平面图形;简单的旋转,改变比例,图块 ;;;只能 用于块, ;;; (defun c:rbk (/ a1 a0 a1e a1n a1_obj szj str jd ssa1 sn n pro a1on ne na1e newa1 cmd newa a1x a1y newaxy str0 str1 roscal )
(setq a1 (entsel "请选择要旋转的块:") a0 (car a1) a1e (entget a0) a1n (assoc 2 a1e) a1_obj (assoc 0 a1e) na1e (assoc 50 a1e) ax (assoc 41 a1e) cmd (getvar "cmdecho") szj (ssadd a0) ) (setq ssa1 (ssget "x" (list a1n))) (setq sn (sslength ssa1)) (sssetfirst ssa1 szj) (princ (strcat "\n您选择的块名为:" (cdr a1n) "; 共有 " (itoa sn) "个。 " "旋转角度为: " (angtos (cdr na1e)) " 比例因子为: " (rtos (cdr ax)) )) (setq str1 (getstring "\n改变块 (角度 J) \\ (块比例 B) <角度>:")) (if (= (STRCASE str1) "B") (progn (Setq str0 (getreal "\n请输入要缩放块的比例: ") a1x (cons 41 str0) a1y (cons 42 str0)
) (setq roscal (strcat "\n比例因子为:" (rtos str0))) )
(progn (setq str (getstring "\n请输入要旋转块的角度(格式: d ' \"): ") jd (angtof str) pro (cons 50 jd) ) (setq roscal (strcat "\n旋转角度为:" str)) ) )
;;; (setq pro (cons 50 jd)) (setq n 0) (if (= (STRCASE str1) "B") (progn (repeat sn (setq a1on (ssname ssa1 n) ne (entget a1on) ax (assoc 41 ne) ay (assoc 42 ne) ) (setq newa (subst a1x ax ne)) (setq newaxy (subst a1y ay newa)) (setq n (1+ n)) (entmod newaxy)
) ) (progn (repeat sn (setq a1on (ssname ssa1 n) ne (entget a1on) na1e (assoc 50 ne) ) (setq newa1 (subst pro na1e ne)) (setq n (1+ n)) (entmod newa1) ) ) ) (sssetfirst nil nil) (setvar "cmdecho" cmd) (alert (strcat "您选择的块名为:" (cdr a1n) "; \n共有 " (itoa sn) " 个 \n被改变为 " roscal ) ) (princ)
) ;定义子函数 ;(defun sa1() ; (setq a1 (entsel "选择要旋转的块") ;;; (princ "\n 您选择的块,共有 ") ;;; (princ sn) ;;; (princ " 同名块。旋转角度为") ;;; (princ str) ; a1e (entget (car a1)) ; a1n (assoc 2 a1e) ; a1_obj (assoc 0 a1e) ; ) ; )
