查看: 1401|回复: 2
vb中创建CAD TOOLBAR出错,请高手指点
发表于 2006-9-15 03:04:00 | 显示全部楼层 |阅读模式
CAD原代码
Private Sub AddToolbar()
    ' This example creates a new toolbar called TestToolbar and inserts a
    ' toolbar button into it. The toolbar is then displayed.
    ' To remove the toolbar after execution of this macro, use the Customize Menu
    ' option from the Tools menu.
    Dim currMenuGroup As AcadMenuGroup
    Set currMenuGroup = acadDoc.Application.MenuGroups.Item(0)  '调试后此行出错
    ' Create the new toolbar
    Dim newToolBar As AcadToolbar
    Set newToolBar = currMenuGroup.Toolbars.Add("TestToolbar")
    ' Add a button to the new toolbar
    Dim newButton As AcadToolbarItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set newButton = newToolBar.AddToolbarButton("", "NewButton", "Open a file.", openMacro)
    ' Display the toolbar
    newToolBar.Visible = True
End Sub
在VB中运行后 提示 :
实时错误 ‘91’
对象变量或with块变量未设置
问题已解决  谢谢
问题已解决  谢谢
问题已解决  谢谢
问题已解决  谢谢
问题已解决  谢谢
发表于 2006-9-15 12:59:00 | 显示全部楼层
把acadDoc改为 thisdrawing 试试
 楼主| 发表于 2006-9-15 14:22:00 | 显示全部楼层
晕~~~ 是在VB6.0里面啊 不是VBA
mccad 在吗?能指点一下吗?
GMT+8, 2025-2-22 05:14 , Processed in 0.134442 second(s), 23 queries , Gzip On.
