查看: 1657|回复: 1
请教一个关于工具条的问题
发表于 2006-9-16 01:59:00 | 显示全部楼层 |阅读模式
Sub Example_AddToolbarButton()
    ' This example creates a new toolbar called TestToolbar and inserts a
    ' toolbar button into it. The toolbar is then displayed.
    ' To remove the toolbar after execution of this macro, use the Customize Menu
    ' option from the Tools menu.
    Dim currMenuGroup As acadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    ' Create the new toolbar
    Dim newToolBar As AcadToolbar
    Set newToolBar = currMenuGroup.Toolbars.Add("TestToolbar")
    ' Add a button to the new toolbar
    Dim newButton As AcadToolbarItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set newButton = newToolBar.AddToolbarButton("", "NewButton", "Open a file.", openMacro)
    ' Display the toolbar
    newToolBar.Visible = True
End Sub
1:上面的代码 可以生成一个工具条,但是关掉生成的toolbar后 ,再运行程序就会出错,
    可能是关掉的toolbar没有卸载完。怎么彻底删除toolbar?
2: 生成的toolbar,上面的按钮只能实现打开、保存等功能,怎么能点击按钮后调用自己
    的函数来实现其他功能?
急切等待您的指点
发表于 2006-9-18 19:56:00 | 显示全部楼层
那是因为已经有了toolbar了
GMT+8, 2025-5-3 19:52 , Processed in 0.143010 second(s), 23 queries , Gzip On.
