查看: 1688|回复: 3
VBA如何访问Access?
发表于 2006-9-18 09:13:00 | 显示全部楼层 |阅读模式
使用AutoCAD VBA如何访问Access数据库?(如何打开,关闭,和定义Access查询的条件?)
发表于 2006-9-21 23:47:00 | 显示全部楼层
是啊,有谁会啊,请教了
发表于 2006-9-26 13:13:00 | 显示全部楼层
1 VB编辑器菜单工具-〉引用,把ActiveX Data Objects 2.8选上,然后确定
2 编写连接代码
'指定数据库文件路径返回一个数据库连接对象Connection
 Function GetConnection(DBPath As String) As Connection
    Dim conn As New Connection
    With conn
    .Provider = "Microsoft.Jet.OLEDB.4.0"
    .ConnectionString = DBPath
    .Open
    End With
    Set GetConnection = conn
End Function
sub test()
dim conn as Connection
dim rs as RecordSet
dim SqlCmd as new Command
Set conn = GetConnection("F:\CAD\CadDataBase\CadDataBase.mdb")
   With SqlCmd
   .ActiveConnection = conn
   .CommandType = adCmdStoredProc '命令类型为存储过程,adCmdText是普通SQL语句
   .CommandText = "Validate" '指出在ACCESS中建立的查询的名称
    End With
rs = SqlCmd.Execute , Array(id,pwd) '给定查询所需要的参数
msgbox rs.Feilds("userName").value
rs.close
conn.close
end sub
 楼主| 发表于 2006-9-29 14:12:00 | 显示全部楼层
研究中……
GMT+8, 2025-5-3 06:41 , Processed in 0.169584 second(s), 23 queries , Gzip On.
