查看: 1751|回复: 0
打印页面设置的问题!
发表于 2006-9-27 11:40:00 | 显示全部楼层 |阅读模式
Dim PlotConfigurations As AcadPlotConfigurations
     Dim plotCon As AcadPlotConfiguration, Dy$
     Set PlotConfigurations = acaddoc.PlotConfigurations
     Set plotCon = PlotConfigurations.Add("55", True)
    ’以下对plotcon的各项属性进行设置
     With plotCon
          .ConfigName = 默认打印机名
         .CanonicalMediaName = "A3"
         .PaperUnits = acMillimeters
         .StyleSheet = "acad.ctb"
         .CenterPlot = True
         .PlotRotation = ac90degrees
         .StandardScale = acScaleToFit
         .PlotType = acExtents
         .PlotWithPlotStyles = True
     End With
‘这里设置plotcon完成以后,如何把plotcon设置为默认的页面设置?????
我一直找不到设置的方法,这样打印图纸的时候要手动在《页面设置名》中选择才可以!
请高手指教一下!
GMT+8, 2025-5-3 05:33 , Processed in 0.142804 second(s), 23 queries , Gzip On.
