对楼上的程序进行了小改动,达到了要求。
(defun c:dqwb () (setq a (ssget (list (cons 0 "text")))) (setq n (sslength a)) (setq all nil) (setq m 0) (while (< m n) (setq all (append all (list (entget (ssname a m))))) (setq m (1+ m)) )
(setq l 0);;按y坐标降序排列 (setq m 1) (while (< l n) (setq b (nth l all)) (while (< m n) (setq c (nth m all)) (if (> (nth 2 (assoc '10 c)) (nth 2 (assoc '10 b))) (progn (setq all (subst 'aa (nth l all) all ) ) (setq all (subst 'bb (nth m all) all ) ) (setq all (subst c 'aa all ) ) (setq all (subst b 'bb all ) ) (setq b c) ) ) (setq m (1+ m)) ) (setq l (1+ l)) (setq m (1+ l)) )
(setq val (getreal "\n行距:")) (setq p (getpoint "\n首行的插入点:")) (setq x0 (car p)) (setq y0 (cadr p))
(setq m 0) (while (< m n) (setq b (nth m all)) (setq y (- y0 (* m val))) (setq z (nth 3 (assoc '10 b))) (setq xyz_new (list '10 x0 y z)) (setq b (subst (cons '72 0) (assoc '72 b) b)) (setq b (subst (cons '73 0) (assoc '73 b) b)) (setq b (subst xyz_new (assoc '10 b) b ) ) (entmod b) (setq m (1+ m)) ) ) (princ "\n===对齐单行文本,自定义行距程序成功加载!命令行以dqwb启动!") |
