查看: 1522|回复: 2
模拟ET工具中的layiso!
发表于 2006-10-18 11:53:00 | 显示全部楼层 |阅读模式
模拟ET工具中的layiso,初学者,程序应该可以做优化,请高手指点:
(defun c:layiso()
          (setvar "cmdecho" 0)
              (princ "\n.....选择所要保留图层上实体......")
       (setq sl (ssget))
       (setq index 0)
       (setq sll (sslength sl))
       (tblnext "layer" T)
       (setq zerolayerentname (tblobjname "layer" "0"))
       (setq  zerotable (entget zerolayerentname))
       (if (> (cdr (assoc '62 zerotable)) 0)
                            (progn     (setq zeroonoff (- 0 (cdr (assoc '62 zerotable))))
                                          (entmod (subst (cons 62 zeroonoff) (assoc '62 zerotable) zerotable))
       (while  (setq entable (tblnext "layer"))
                     (setq layerentname (tblobjname "layer" (cdr (assoc '2 entable))))
                     (setq  ennewtable (entget layerentname))
                     (if (> (cdr (assoc '62 ennewtable)) 0)
                            (progn     (setq layeronoff (- 0 (cdr (assoc '62 ennewtable))))
                                          (entmod (subst (cons 62 layeronoff) (assoc '62 ennewtable) ennewtable))
       (repeat sll
                     (setq entname (ssname sl index))
            (setq entable (entget entname))
            (setq layername (tblobjname "layer" (cdr (assoc '8 entable))))
            (setq ennewtable (entget layername))
            (if (< (cdr (assoc '62 ennewtable)) 0)
                (progn     (setq layeronoff (- (cdr (assoc '62 ennewtable)) (* 2 (cdr (assoc '62 ennewtable)))))
                                          (setq layertable (subst (cons 62 layeronoff) (assoc '62 ennewtable) ennewtable))
                                          (entmod layertable)
           (setq index (+ 1 index))
        (princ "\n操作已完成,保留了你所需的图层!")
发表于 2006-10-19 14:29:00 | 显示全部楼层
给你一个我自己写的吧,应该可以的
;;;将选定对象所在图层保留,其它图层关闭
(DEFUN CO (/ &OLDERR&        *$MYERROR$*     *ERROR*      LAY
           ACADDOCUMENT ACADOBJECT     ENAME          INDEX
           LAYER        LAYERLST     LAYERSOBJ    SS
           VL_ENAME
  (VL-LOAD-COM)
  (DEFUN *$MYERROR$* (MSG)
    (SETQ *ERROR* &OLDERR&)
    (PRINC)
  (SETQ &OLDERR& *ERROR*)
  (SETQ *ERROR* *$MYERROR$*)
  (SETQ ACADOBJECT (VLAX-GET-ACAD-OBJECT))
  (SETQ ACADDOCUMENT (VLAX-GET-PROPERTY ACADOBJECT 'ACTIVEDOCUMENT))
  (SETQ LAYERSOBJ  (VLA-GET-LAYERS ACADDOCUMENT))
  (PRINC "\n请选择欲保留的图层上的对象:")
  (SETQ SS (SSGET))
  (SETQ LIST_LAYER NIL)
  (SETQ INDEX -1)
  (WHILE (SETQ ENAME (SSNAME SS (SETQ INDEX (1+ INDEX))))
    (SETQ VL_ENAME (VLAX-ENAME->VLA-OBJECT ENAME))
    (SETQ LAYER (VLA-GET-LAYER VL_ENAME))
    (IF    (NOT (MEMBER LAYER LIST_LAYER))
      (SETQ LIST_LAYER (CONS LAYER LIST_LAYER))
  (VLAX-FOR LAY LAYERSOBJ
    (VLA-PUT-LAYERON LAY :VLAX-FALSE)
  (FOREACH LAYER LIST_LAYER
    (VLA-PUT-LAYERON (VLA-ITEM LAYERSOBJ LAYER) :VLAX-TRUE)
  (PRINC)
发表于 2006-11-4 22:30:00 | 显示全部楼层
我们公司用的就是这个,还是很好用的。
GMT+8, 2025-9-19 03:54 , Processed in 0.201679 second(s), 25 queries , Gzip On.
