查看: 1785|回复: 3
[求助]我的根据库里坐标绘pl线时遇到的问题
发表于 2006-10-20 08:52:00 | 显示全部楼层 |阅读模式
我大伙帮我看看我的vba怎么回事!
Sub ll()
Dim cn As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim klj, blj, blj2 As String
Dim tysx As String
Dim id, js As Long
Dim i As Integer
Dim objpline As AcadLWPolyline
blj = "select * from pline"
klj = "provider=sqloledb.1;password=;persist security info=true;user id=sa;initial catalog=cadsql ;data source=huangbin" '库连接字符串
'klj = "Provider=MSDASQL.1ersist Security Info=False;Data Source=hbsql"
cn.Open klj '连接数据库
rst.Open blj, cn, adOpenForwardOnly, adLockBatchOptimistic
Dim pt() As Variant
Do While Not rst.EOF
js = js + 1
   rst.MoveNext
Loop
rst.Close
ReDim pt(js - 1, 2)
i = -1
   i = i + 1
   pt(i, 0) = rst.Fields("x")
   pt(i, 1) = rst.Fields("y")
   pt(i, 2) = 0
   rst.MoveNext
Loop
'ThisDrawing.ModelSpace.AddLine pt
Set objpline = ThisDrawing.ModelSpace.AddLightWeightPolyline_(pt)
rst.Close
cn.Close
End Sub
总是提示说:对象不支持该属性或方法!
我是刚接触vba的请高手们赐教!!!
发表于 2006-10-20 09:55:00 | 显示全部楼层
AddLightWeightPolyline(pt)
该pt是一组二维的坐标值,没有z值的,把z值去掉就能通过了
 楼主| 发表于 2006-10-20 11:15:00 | 显示全部楼层
请问我把z值去掉了怎么还是不行的?
 楼主| 发表于 2006-10-20 13:58:00 | 显示全部楼层
高手们指点指点我!我是百思不得其解呀~
GMT+8, 2025-5-3 04:21 , Processed in 0.266890 second(s), 23 queries , Gzip On.
