查看: 1600|回复: 1
取图元颜色和线型有大问题?????
发表于 2006-10-27 15:15:00 | 显示全部楼层 |阅读模式
AcadSelectionSet 取图元颜色和线型
AcadSelectionSet 取图元颜色和线型,在不同图层内,只以取到256这个值
代码如下:
Sub main()
  Dim sets As AcadSelectionSet
  Dim i As Integer
  Set sets = ThisDrawing.SelectionSets.Add("Select")
  sets.SelectOnScreen
  For i = 0 To sets.Count - 1
    MsgBox "当前颜色值为:" & sets.Item(i).color
  Next i
  sets.Delete
End Sub
谢谢!!!
 楼主| 发表于 2006-10-27 15:47:00 | 显示全部楼层
Sub main()
  Dim i As Integer
  sets.SelectOnScreen
     If sets.Item(i).color = 256 Then
        MsgBox "当前颜色值为:" & ThisDrawing.Layers.Item(sets.Item(i).Layer).TrueColor.ColorIndex
     Else
     End If
  Next i
  sets.Delete
End Sub
这样解决行吗
GMT+8, 2025-5-3 03:05 , Processed in 0.158821 second(s), 24 queries , Gzip On.
