好多人在找的!我给提供个源代码! 3T2
谁给做个2D线改3D的?
(defun 3DLIST(ENTNAME LORPL) (setq cbiao nil) (if (/= LORPL "LINE") (PROGN (SETQ BIA (ENTGET ENTNAME)) (WHILE (/= LORPL "SEQEND") (SETQ ENTNAME (ENTNEXT ENTNAME)) (SETQ BIA (ENTGET ENTNAME)) (SETQ LORPL (CDR (ASSOC 0 BIA))) (if (/= LORPL "SEQEND") (SETQ CBIAO (CONS (CDR (ASSOC 10 BIA)) CBIAO)) );if );while );progn (progn (SETQ BIA (ENTGET ENTNAME)) (SETQ CBIAO (CONS (CDR (ASSOC 11 BIA)) CBIAO)) (SETQ CBIAO (CONS (CDR (ASSOC 10 BIA)) CBIAO)) );progn );if );end ;============================================================================= ;数表处理 (defun sbcl21() (progn (setq newlib nil) (setq mm2 0) (setq ll2 (length cbiao)) (while (< mm2 ll2) (progn (setq gczjq1 (nth mm2 cbiao)) ;(setq jq (list (car gczjq1) (cadr gczjq1) 0)) (setq jq gczjq1) );progn (setq newlib (cons jq newlib)) (setq mm2 (+ mm2 1)) );while (setq newlib (reverse newlib)) (progn (command "layer" "s" entlay "") (setq kk 0) (setq kk1 (length newlib)) (command "pline") (repeat kk1 (command (nth kk newlib)) (setq kk (+ kk 1)) );repeat (command) (command "erase" entname1 "") (command "redraw") );progn );progn );end ;=============================================================================== ;选线处理数据 (defun xzxpcl21() (setq sss nil) (setq ss2 (ssget)) (if (/= ss2 nil) (progn (setq sss ss2) );progn (progn (princ "\n没有选线!") (princ) );progn );if );end ;=============================================================================== ;选全图线处理数据 (defun xzqtpcl21() (setq sss nil) (setq ss3 (ssget "X")) (if (/= ss3 nil) (progn (setq sss ss3) );progn (progn (princ "\n图是空的!") (princ) );progn );if );end ;=============================================================================== ;按层处理数据 (defun xzcpcl21() (setq sss nil) (setq layname (getstring "\n请输入要处理的三维线所在层名:")) (if (/= layname nil) (progn (if (tblsearch "layer" layname) (progn (setq ss1 (ssget "X" (list (cons 8 layname)))) (if (/= ss1 nil) (progn (setq sss ss1) );progn (progn (princ "\n本图中 ") (princ layname) (princ " 层无要素!") (princ) );progn );if );progn (progn (princ "\n本图中 ") (princ layname) (princ " 层不存在!") (princ) );progn );if );progn (progn (princ "\n没有输入层名!") (princ) );progn );if );end ;=============================================================================== (defun c:3t2() (progn (progn (initget "1 2 3") (princ "\n选择三维线改二维线方式:") (setq key (getkword "\n1选线\\2输入层\\3全图线\\<回车为输入层>:")) (cond ((not key) (xzcpcl21)) ;选择层批处理 ((= key "1") (xzxpcl21)) ;选择线批处理 ((= key "2") (xzcpcl21)) ;选择层批处理 ((= key "3") (xzqtpcl21)) ;选择全图批处理 );cond );progn (if (/= sss nil) (progn (progn (princ "\n正在处理数据,请稍等...") (princ) );progn (setq mm1 0) (setq ll1 (sslength sss)) (while (< mm1 ll1) (setq entname1 (ssname sss mm1)) (setq entsj1 (entget entname1)) (setq entlx1 (cdr (assoc 0 entsj1))) (setq entlay (cdr (assoc 8 entsj1))) (if (or (= entlx1 "LINE") (= entlx1 "POLYLINE")) (progn (3dlist entname1 entlx1) ;获得表数据 (sbcl21) ;构造表数据处理 );progn (progn (princ) );progn );if (setq mm1 (+ mm1 1)) );while (progn (princ "\n共处理 ") (princ ll1) (princ " 条数据.") (princ) );progn );progn (progn (princ "\n没有选择线或层中无数据!") (princ) );progn );if );progn );end ;===============================================================================
