查看: 1315|回复: 1
如何知道一条polyline有多少点呀?
发表于 2006-11-4 10:53:00 | 显示全部楼层 |阅读模式
Sub getpolyline()
    Dim i, n As Integer
    'Dim newObjs As AcadPolyline
    Dim newObjs As AcadLWPolyline   'Object drawed by pline command under version 2006
    Dim retCoord As Variant
    Dim points(500) As Double
  n = ThisDrawing.ModelSpace.Count
  For i = 0 To n - 1
      If ThisDrawing.ModelSpace.Item(i).ObjectName = "AcDbPolyline" Then
         Set newObjs = ThisDrawing.ModelSpace.Item(i)
         'newObjs怎么老是空的?下面的结果老不对
         ' Return all the coordinates of the polyline
         retCoord = newObjs.Coordinates
         mynpoint = (UBound(retCoord) + 1) / 3
      End If
  Next i
  MsgBox "Good on ya!"
End Sub
 楼主| 发表于 2006-11-4 11:42:00 | 显示全部楼层
把mynpoint = (UBound(retCoord) + 1) / 3中的除3改成除2,结果好像对了。我还以为定点存的是x,y,z三个坐标呢。3dpoly应该是x,y,z了吧。
GMT+8, 2025-5-3 08:13 , Processed in 0.155156 second(s), 24 queries , Gzip On.
