查看: 1678|回复: 3
把xy平面上的polyline转到zy平面去
发表于 2006-11-4 13:00:00 | 显示全部楼层 |阅读模式
先用下面例程生成polyline
Sub Example_AddLightWeightPolyline()
    ' This example creates a lightweight polyline in model space.
    Dim plineObj As AcadLWPolyline
    Dim points(0 To 9) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1
    points(2) = 1: points(3) = 2
    points(4) = 2: points(5) = 2
    points(6) = 3: points(7) = 2
    points(8) = 4: points(9) = 4
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ZoomAll
End Sub
然后用下面的例程旋转
Sub getpolyline()
    Dim UserMessage As String
    Dim ControlPoints As Variant
    Dim iCount As Long, iPoint As Integer
    Dim i, n As Integer
    'Dim newObjs As AcadPolyline
    Dim newObjs As AcadLWPolyline
    Dim retCoord As Variant
    Dim points(200) As Double
    Dim coord As Variant
    Dim polyObj As Acad3DPolyline
  n = ThisDrawing.ModelSpace.Count
  'MsgBox "N = " & Str(n)
  For i = 0 To n - 1
      If ThisDrawing.ModelSpace.Item(i).ObjectName = "AcDbPolyline" Then
         Set newObjs = ThisDrawing.ModelSpace.Item(i)
         mynpoint = (UBound(newObjs.Coordinates) + 1) / 2
         For J = 0 To mynpoint - 1
             coord = newObjs.Coordinate(J)
             points(3 * J) = 0
             points(3 * J + 1) = coord(1)
             points(3 * J + 2) = coord(0)
         Next J
         ' Create a 3DPolyline in model space
         Set polyObj = ThisDrawing.ModelSpace.Add3DPoly(points)
      End If
  Next i
  MsgBox "Good on ya!"
End Sub
问题是转完了老有一条连接polyline最后定点与坐标原点的连线。问题在那?
我觉得是生成3dpolyline时,定点points数组的大小定义的有多余的空间。该怎么解决呢?
发表于 2006-11-12 23:34:00 | 显示全部楼层
有用,顶一下。
 楼主| 发表于 2006-11-13 17:54:00 | 显示全部楼层
现在发现用rotate3d命令也可以。
发表于 2006-11-13 22:49:00 | 显示全部楼层
就是用rotate3d命令。
GMT+8, 2025-5-2 17:57 , Processed in 0.146030 second(s), 23 queries , Gzip On.
