查看: 1224|回复: 2
请教高手:选择集的应用程序是这样吗?
发表于 2006-11-4 17:15:00 | 显示全部楼层 |阅读模式
假如上一步骤画一直线,图元名设为en1,再画一圆,图元名设为en2,
将两者添加到同一个选择集sec中,程序如下:
 (setq  sec  en1)
 (ssadd   en2  sec)
运行后好像sec中不含en2,不行啊,哪位高手请指导指导,急用!!!!
谢谢谢………………
 楼主| 发表于 2006-11-4 18:22:00 | 显示全部楼层
但像我上面的两句程序那样,程序不会报错啊!!
高手帮忙………………
发表于 2006-11-4 20:12:00 | 显示全部楼层
Set e1 to the name of the first entity in drawing:
Command: (setq e1 (entnext))
<Entity name: 1d62d60>
Set ss to a null selection set:
Command: (setq ss (ssadd))
<Selection set: 2>
The following command adds the e1 entity to the selection set referenced by ss:
Command: (ssadd e1 ss)
<Selection set: 2>
Get the entity following e1:
Command: (setq e2 (entnext e1))
<Entity name: 1d62d68>
Add e2 to the ss entity:
Command: (ssadd e2 ss)
<Selection set: 2>
GMT+8, 2025-9-19 03:58 , Processed in 0.156854 second(s), 27 queries , Gzip On.
