查看: 1603|回复: 0
[求助]yshf的程序对3D线怎么不能操作啊?
发表于 2006-11-4 17:32:00 | 显示全部楼层 |阅读模式
;;请试用以下程序
;;by yshf
(defun c:cc ()
    (setq cm (getvar "cmdecho") om (getvar "osmode"))
    (setvar "osmode" 0)
    (command "_undo" "be")
    (setq  dd (getdist (strcat "\n请输入要断开的长度<"
          (rtos (getvar "userr1")) ">:"
    (if dd (setvar "userr1" dd)(setq dd (getvar "userr1")))
    (while (setq ent (car (entsel "\n请一条基准线:")))
       (setq dxf (entget ent)
      p1  (cdr (assoc 10 dxf))
      p2  (cdr (assoc 11 dxf))
       (if (setq ssa (ssdel ent (ssget "f" (list p1 p2) '((0 . "LINE")))))
              (setq i 0  n (sslength ssa))
       (repeat n
          (setq en2 (ssname ssa i)
         dxf (entget en2)
         p3  (cdr (assoc 10 dxf))
         p4  (cdr (assoc 11 dxf))
         pt  (inters p1 p2 p3 p4)
                 (command "_circle" pt (/ dd 2.0))(setq en1 (entlast))
                 (command "_trim" (entlast) "" (list en2 pt) "")
                 (entdel en1)
                 (setq i (1+ i))
    (command "_undo" "e")
    (setvar "osmode" om)(setvar "cmdecho" cm)(princ)
GMT+8, 2025-9-19 03:54 , Processed in 0.374983 second(s), 26 queries , Gzip On.
