查看: 1377|回复: 0
[求助]过滤桢同数据的问题
发表于 2006-11-5 12:42:00 | 显示全部楼层 |阅读模式
Sub N12()
     On Error Resume Next
       Dim ENT As AcadEntity
       Dim sset As AcadSelectionSet
       Dim objtext As AcadText
       If Not IsNull(ThisDrawing.SelectionSets.Item("TEXT")) Then
       Set sset = ThisDrawing.SelectionSets.Item("TEXT")
       sset.Delete
       End If
       Set sset = ThisDrawing.SelectionSets.Add("TEXT")
       Dim filtertype(0) As Integer
       Dim filterdata(0) As Variant
     filtertype(0) = 0
     filterdata(0) = "text"
     sset.selectonscreen filtertype, filterdata
     Dim count As Long
     count = sset.count
     Dim text1()
     ReDim text1(count)
     Dim i As Long
     For i = 0 To sset.count - 1
     Set text1(i) = sset.Item(i)
     Next
     MsgBox UBound(text1)
    ' For i = LBound(text1) To UBound(text1)
     'MsgBox text1(i).TextString
     'Next
     Dim newarray()
     newarray = getArray(text1)
        MsgBox newarray(i).TextString
     Next
End Sub
此过程为何不能显示过滤后的字符?
GMT+8, 2025-5-3 08:17 , Processed in 0.150125 second(s), 23 queries , Gzip On.
