查看: 1506|回复: 2
如何做一个程序同时支持两个版本的AutoCAD?
发表于 2006-11-6 16:16:00 | 显示全部楼层 |阅读模式
请问如何在VB6中做一个画园的程序,使得它可以同时支持AutoCAD2005和AutoCAD2007?
发表于 2006-11-7 08:17:00 | 显示全部楼层
打开或获取cad时不要指定版本就可以啊
发表于 2006-11-7 11:41:00 | 显示全部楼层
如下就好了。
Dim obj_Acad As Object
Dim obj_Doc  As Object
Sub Main()
On Error Resume Next
Set obj_Acad = GetObject(, "autocad.application")
If Err Then
   Err.Clear
   Set obj_Acad = CreateObject("autocad.application")
   If Err Then
      Err.Clear
      MsgBox "不能运行AutoCAD,请检查是否安装!", vbOKOnly, "警告!"
      Exit Sub
      End If
End If
obj_Acad.Visible = True
obj_Acad.WindowState = autocad.acwindowstate.acmax
AppActivate (obj_Acad.Caption)
Set obj_Doc = obj_Acad.ActiveDocument
obj_Doc.SendCommand ("(setq p2c::filepath """ + Replace(App.Path, "\", "\\") + "\\"") ")
obj_Doc.SendCommand ("(load (strcat p2c::filepath ""Part2CAM.fas"")) ")
obj_Doc.SendCommand ("(princ) ")
End Sub
GMT+8, 2025-5-3 08:28 , Processed in 0.167097 second(s), 24 queries , Gzip On.
