当然你也可以使用一下下面的程序 注意轴承数据库没有完善,要检查一下哦 不要对你的设计工件产生致命影响哦 ;;深沟球轴承绘制程序 ;;Copyrignt Lin chengqiang 2006 for mengyang (defun c:zc () (setvar "cmdecho" 0) (prompt "\n-->本程序的轴承数据库还尚未完善,如果你已经将本代码进行修改或完善了 " ) (prompt "\n-->轴承数据库请你将本段代码发送给我 ") (setq p0 (getpoint "\n--> 指定轴承的安装位置:")) (command "purge" "a" "*" "n" "y") (command "ortho" "on") (command "osnap" "int,mid") (command "layer" "n" "MAIN" "c" "7" "MAIN" "") (command "layer" "n" "CENTER" "c" "1" "CENTER" "") (command "layer" "n" "DIM" "c" "5" "DIM" "") (command "layer" "n" "HIDD" "c" "3" "HIDD" "") (command "layer" "n" "HATCH" "c" "6" "HATCH" "") (command "layer" "n" "2" "c" "2" "2" "") (command "layer" "l" "hidden2" "HIDD" "") (command "layer" "l" "center2" "CENTER" "") (setq p1 (getpoint p0 "\n--> 指定轴承的旋转方向:")) (setq ang (angle p0 p1)) (setq angci (* (/ 60.0 180.0) pi)) (setq ang$ (* (/ 90.0 180.0) pi)) (setq ang$$ (* (/ 180.0 180.0) pi)) (setq mod (getstring "\n--> 指定轴承的型号:")) (cond ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6001") (setq d 12.0) (setq d1 28.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6002") (setq d 15.0) (setq d1 32.0) (setq b 9.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6003") (setq d 17.0) (setq d1 35.0) (setq b 10.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6004") (setq d 20.0) (setq d1 42.0) (setq b 12.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6005") (setq d 25.0) (setq d1 47.0) (setq b 12.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6006") (setq d 30.0) (setq d1 55.0) (setq b 13.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6007") (setq d 35.0) (setq d1 62.0) (setq b 14.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6008") (setq d 40.0) (setq d1 68.0) (setq b 15.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6009") (setq d 45.0) (setq d1 75.0) (setq b 16.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6010") (setq d 50.0) (setq d1 80.0) (setq b 16.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6011") (setq d 55.0) (setq d1 90.0) (setq b 18.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6012") (setq d 60.0) (setq d1 95.0) (setq b 18.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6200") (setq d 10.0) (setq d1 30.0) (setq b 9.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6201") (setq d 12.0) (setq d1 32.0) (setq b 10.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6202") (setq d 15.0) (setq d1 35.0) (setq b 11.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6203") (setq d 17.0) (setq d1 40.0) (setq b 11.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6204") (setq d 20.0) (setq d1 47.0) (setq b 14.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6205") (setq d 25.0) (setq d1 52.0) (setq b 15.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6206") (setq d 30.0) (setq d1 62.0) (setq b 16.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6207") (setq d 35.0) (setq d1 72.0) (setq b 17.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6208") (setq d 40.0) (setq d1 80.0) (setq b 18.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6209") (setq d 45.0) (setq d1 85.0) (setq b 19.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6210") (setq d 50.0) (setq d1 90.0) (setq b 20.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6211") (setq d 55.0) (setq d1 100.0) (setq b 21.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6212") (setq d 60.0) (setq d1 120.0) (setq b 22.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ((= mod "6000") (setq d 10.0) (setq d1 26.0) (setq b 8.0) (setq a (/ (- d1 d) 2.0)) ) ) (SETQ SCALE (getvar "dimscale")) (setq q1 (polar p0 ang (/ d 2.0))) (setq q2 (polar q1 ang a)) (setq q3 (polar q2 (- ang ang$) b)) (setq q4 (polar q3 (+ ang ang$$) a)) (command "osnap" "off") (command "layer" "s" "MAIN" "") (command "pline" q1 q2 q3 q4 q1 "") (setq l1 (expt a 2)) (setq l2 (expt b 2)) (setq ll (/ (sqrt (+ l1 l2)))) (setq cang (angle q1 q3)) (setq c1 (polar q1 cang (/ ll 2.0))) (setq cr (/ a 2.0)) (command "circle" c1 "d" cr) (setq h1 (polar c1 (- ang (* (/ 60.0 180.0) pi)) (/ cr 2.0))) (setq h2 (polar c1 (+ ang (* (/ 60.0 180.0) pi)) (/ cr 2.0))) (setq h3 (polar c1 (+ ang (* (/ 120.0 180.0) pi)) (/ cr 2.0))) (setq h4 (polar c1 (- ang (* (/ 120.0 180.0) pi)) (/ cr 2.0))) (setq m1 (polar h1 (- ang (* (/ 90.0 180.0) pi)) b)) (setq m2 (inters q3 q4 h1 m1 nil)) (setq m3 (distance h1 m2)) (setq h11 (polar h1 (- ang (* (/ 90.0 180.0) pi)) m3)) (setq h12 (polar h2 (+ ang (* (/ 90.0 180.0) pi)) m3)) (setq h13 (polar h3 (+ ang (* (/ 90.0 180.0) pi)) m3)) (setq h14 (polar h4 (- ang (* (/ 90.0 180.0) pi)) m3)) (command "ortho" "off") (command "pline" h1 h11 "") (command "pline" h2 h12 "") (command "pline" h3 h13 "") (command "pline" h4 h14 "") (setq ha1 (polar c1 ang (+ (/ cr 2.0) 1.0))) (setq ha2 (polar c1 (+ ang (* (/ 180.0 180.0) pi)) (+ (/ cr 2.0) 1.0)) ) (command "layer" "s" "hatch" "") (command "BHATCH" ha1 ha2 "p" "ANSI31" SCALE "0" "") (setq mi1 (polar p0 (+ ang (* (/ 90.0 180.0) pi)) 3)) (setq mi2 (polar p0 (- ang (* (/ 90.0 180.0) pi)) (+ b 3))) (command "mirror" "c" q1 q3 "" mi1 mi2 "n") (command "layer" "s" "center" "") (command "line" mi1 mi2 "") (command "osnap" "int,nea") (command "osnap" "end,int,mid,cen,per,app") ) |
