查看: 1643|回复: 5
谁帮忙看看这个画矩形的程序错在哪里?
发表于 2006-11-8 23:18:00 | 显示全部楼层 |阅读模式
如下程序运行时提示:参数太少。不知道是什么原因,请各位大哥帮忙看看 啊
对话框定义:
RECT:dialog
 label="Rectangle" ;
 :edit_box  //编辑框元件
 label="Rectangle width : " ;
  key="RECT_W" ;
  edit_limit=16;
  edit_width=10;
  fixed_width=true;
 :edit_box  //编辑框元件
  label="Rectangle heigth :" ;
  key="RECT_H" ;
  edit_limit=16;
  edit_width=10;
  fixed_width=true;
 ok_only;
LISP驱动程序:
(DEFUN C:RECT()
 (SETQ DCL_ID (LOAD_DIALOG "D:/wen jin/AutoCAD/second/rect/rect.dcl"))
 (NEW_DIALOG "RECT" DCL_ID)
 (SET_TILE "RECT_W" "50.0")
 (SET_TILE "RECT_H" "25.0")
 (ACTION_TILE "accept" "(S_RECT)(DONE_DIALOG)")
 (START_DIALOG)
 (UNLOAD_DIALOG)
 (SETQ PT_0 (GETPOINT "\nSelect rectangle lower left point : ")
 (SETQ PT_1 (POLAR PT_0 0 TMP_W)
       PT_2 (POLAR PT_1 (/ PI 2) TMP_H)
       PT_3 (POLAR PT_2 PI TMP_W)
 (COMMAND "PLINE" PT_0 PT_1 PT_2 PT_3 "C")
 (PRINC)
(DEFUN S_RECT()
  (SETQ TMP_W (ABS (ATOF (GET_TILE "RECT_W")))
      TMP_H (ABS (ATOF (GET_TILE "RECT_H")))
发表于 2006-11-9 08:08:00 | 显示全部楼层
(ACTION_TILE "accept" "(S_RECT)(DONE_DIALOG 1)") 我中发现这一处。
 楼主| 发表于 2006-11-9 13:00:00 | 显示全部楼层
我调试了,还是不能正常运行,提示说:参数太少!!!
那位高手再帮忙看看??
发表于 2006-11-9 17:21:00 | 显示全部楼层
   (unload_dialog) →(unload_dialog DCL_ID)
发表于 2006-11-9 20:23:00 | 显示全部楼层
对,楼上的对,我没看出来。
 楼主| 发表于 2006-11-9 20:42:00 | 显示全部楼层
万分感谢!!!
程序已经成功!!!
GMT+8, 2025-6-21 04:18 , Processed in 0.160118 second(s), 25 queries , Gzip On.
