查看: 1260|回复: 0
[求助]大家帮我看看我的错误出在那
发表于 2006-11-9 16:31:00 | 显示全部楼层 |阅读模式
下面是我的语句运行时要出错!总是提醒在此上下文中不允许使用"tysx",此处只允许使用常量 ,表达式,或变量,不允许使用列名.可tysx就是变量!清高手指点
 Sub tylk() '图元连库
Dim cn As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim klj, blj As String
Dim tysx As String
Dim id, cadid, js As Long
Dim mytime As Date
Dim dds As Integer
Dim plzb As Variant '顶点坐标数组
'mytime = Day(Now) + 37024
 mytime = 37025
blj = "select * from tysx"
klj = "provider=sqloledb.1;password=;persist security info=true;user id=sa;initial catalog=cadsql
;data source=huangbin" '库连接字符串
'klj = "Provider=MSDASQL.1ersist Security Info=False;Data Source=hbcad"
cn.Open klj '连接数据库
Dim obj As AcadEntity
'rst.Open blj, cn, adOpenDynamic, adLockBatchOptimistic
For Each obj In ThisDrawing.ModelSpace
tysx = obj.ObjectName
plzb = obj.Coordinates
dds = (UBound(plzb) + 1) / 2
Dim i As Integer
Dim point As Variant
    rst.Open "select * from tysx where  cadid =" & obj.ObjectID & "", cn, adOpenStatic,
adLockReadOnly
    If Not rst.EOF Then
    id = rst.Fields("cadid")
    cadid = rst.Fields("cadid")
    End If
    rst.Close
    If cadid = obj.ObjectID Then
     cn.Execute "update tysx set area=" & obj.Area & ",lasttime=" & mytime & " where cadid=" &
obj.ObjectID & ""
    Else
   'cn.Execute "insert into tysx values (" & obj.ObjectID & ", 44 , " & obj.Area & "," & obj.Area &
   cn.Execute "insert into tysx values (" & obj.ObjectID & ", tysx , " & obj.Area & ", " & mytime &
   End If
   rst.Close
findid rst, obj, cn
Next obj
End Sub
'图形中删除图元时库中也删除。
Private Sub findid(rst, obj As AcadEntity, cn)
Dim js As Integer
   Do While Not rst.EOF
     js = 0
       If rst.Fields("cadid") = obj.ObjectID Then
       js = js + 1
       End If
       'cn.Execute "delete tytable where id= " & obj.ObjectID & ""
     Next obj
     If js = 0 Then
     cn.Execute "delete tysx where cadid=" & rst.Fields("cadid") & ""
     End If
     rst.MoveNext
   Loop
rst.Close
End Sub
GMT+8, 2025-5-2 17:30 , Processed in 0.153340 second(s), 23 queries , Gzip On.
