查看: 3242|回复: 3
关于insertblock方法,请高手解惑!
发表于 2006-11-15 22:25:00 | 显示全部楼层 |阅读模式
Option Explicit
Public Sub textatt()
Dim objrefer As Variant
Dim strname As String
Dim objblock As AcadBlock
Dim dblx As Double
Dim dbly As Double
Dim dblz As Double
Dim dblrotation As Double
On Error Resume Next
dblx = 0
dbly = 0
dblz = 0
dblrotation = 0
With ThisDrawing.Utility
ThisDrawing.Utility.InitializeUserInput 1
objrefer = .GetPoint(, vbCr & "pick the inserpoint:")
End With
Set objblock = ThisDrawing.ModelSpace.insertblock(objrefer, "M:\f-0002.dwg", dblx, dbly, dblz, dblrotation)
If Err Then MsgBox "unable to insert this block."
End Sub
为什么不能插入该文件中的块呢?
谢先!
发表于 2006-11-16 08:46:00 | 显示全部楼层
 楼主| 发表于 2006-11-16 22:10:00 | 显示全部楼层
谢谢,我会继续深入研究的!!!有空请教!!!
发表于 2006-11-17 14:46:00 | 显示全部楼层
dblx = 0
dbly = 0
dblz = 0
x,y,z轴比例不能为0
GMT+8, 2025-5-2 18:05 , Processed in 0.172294 second(s), 23 queries , Gzip On.
