查看: 1789|回复: 2
[求助][ARX]来看看代码,运行两次CAD就崩溃
发表于 2006-11-20 16:46:00 | 显示全部楼层 |阅读模式
照搬照抄了一个addline的小程序,加载后在CAD中使用该命令绘制line后无显示,但命令行提示success,第二次使用后CAD崩溃,请教一下是怎么回事情,谢谢了,代码如下:
// ex03.cpp : 定义 DLL 应用程序的入口点。
#include "stdafx.h"
#include <adslib.h>
#include <rxdlinkr.h>
#include <aced.h>
#include <dbents.h>
#include <geassign.h>
#include <dbsymtb.h>
#include <dbapserv.h>
//----- DLL Entry Point
Acad::ErrorStatus
postToDatabase(AcDbEntity* pEnt,AcDbObjectId& idObj)
 Acad::ErrorStatus es;
 AcDbBlockTable* pBlockTable;
 AcDbBlockTableRecord* pSpaceRecord;
 if(acdbHostApplicationServices()->workingDatabase()==NULL)
  return Acad::eNoDatabase;
 if ((es=acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlockTable,AcDb::kForRead))==Acad::eOk)
  if((es==pBlockTable->getAt(ACDB_MODEL_SPACE,pSpaceRecord,AcDb::kForWrite))==Acad::eOk)
   if((es=pSpaceRecord->appendAcDbEntity(idObj,pEnt))==Acad::eOk)
    pEnt->close();
   pSpaceRecord->close();
  pBlockTable->close();
 return es;
Acad::ErrorStatus newLine()
 ads_point pt1,pt2;
 int retval;
 try
  if((retval=acedGetPoint(NULL, "\nSelect lower left:",pt1))!=RTNORM)
   throw retval;
  if((retval=acedGetPoint(pt1,"\nSelect upper right:",pt2))!=RTNORM)
   throw retval;
 catch (int e)
  if(e==RTCAN)
   return Acad::eUserBreak ;
  if(e==RTERROR)
   return Acad::eInvalidInput ;
 AcDbLine* pLine =new AcDbLine(asPnt3d(pt1),asPnt3d(pt2));
 if(!pLine)
  acedAlert("Not enough memory to create a Line!");
  return Acad::eOutOfMemory ;
 AcDbObjectId id;
 return postToDatabase(pLine,id);
void addLineCommand()
 if(newLine()==Acad::eOk)
  acutPrintf("Success\n");
 else
  acutPrintf("Failed\n");
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void*pkt)
 switch(msg)
 case AcRx::kInitAppMsg:
  acrxDynamicLinker->unlockApplication(pkt);
  acrxDynamicLinker->registerAppMDIAware(pkt);
  //注册命令
  acedRegCmds->addCommand("EXAM03","addline","addline",ACRX_CMD_MODAL,addLineCommand);
  break;
 case AcRx::kUnloadAppMsg:
   acedRegCmds->removeGroup("EXAM03");
   break;
 return AcRx::kRetOK;
BOOL APIENTRY DllMain( HANDLE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved
    return TRUE;
发表于 2006-11-21 09:05:00 | 显示全部楼层
这句有问题
 楼主| 发表于 2006-11-21 10:27:00 | 显示全部楼层
if((es=pBlockTable->getAt(ACDB_MODEL_SPACE,pSpaceRecord,AcDb::kForWrite))==Acad::eOk)
多了一个=号,语法上检查不出来,谢谢了!
GMT+8, 2025-5-25 06:47 , Processed in 0.165945 second(s), 23 queries , Gzip On.
