查看: 1925|回复: 0
VBA致命错误,谁有经验
发表于 2006-11-21 10:34:00 | 显示全部楼层 |阅读模式
单位新近从2005升级到2007,然后就有了怪问题,大部分电脑中VBA都不能正常启动,CAD菜单的宏下面所有的几个都不能点,一点CAD就致命错误,用命令也不行,但CAD其它一切正常。而且,CAD2005和Office中的VBA工作正常。重新安装也一样,激活前和激活后都不行,关闭一些杀毒等程序,还是这样。察看Windows的事件察看器,得到下列提示:The description for Event ID ( 0 ) in Source ( .NET Runtime ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: Unable to open shim database version registry key - v2.0.50727.00000.
有人能帮助我吗?
GMT+8, 2025-2-22 18:28 , Processed in 0.161433 second(s), 23 queries , Gzip On.
