查看: 2798|回复: 3
不打开CAD 读取.dwg文件内部的实体元素的信息
发表于 2006-11-21 12:27:00 | 显示全部楼层 |阅读模式
在不打开CAD软件的情况下,通过程序读取.dwg文件内部的实体元素的信息,这个想法能否实现,若能实现用什么技术可以实现,希望版主和对这方面了解的同仁给与解答。
发表于 2007-1-12 11:00:00 | 显示全部楼层
有的,ODT技术就是做这个的
发表于 2007-1-16 12:15:00 | 显示全部楼层
朋友,我和你的问题一样,搞出来了没?
发表于 2007-2-24 17:41:00 | 显示全部楼层
如下代码可以实现
void
clone3()
    AcDbObjectId id;
    AcDbObjectIdArray list;
    AcDbDatabase extDatabase( Adesk::kFalse );
    char dwgName[_MAX_PATH];
    if (RTNORM != getFile( "Enter DWG name", "Select Drawing", "dwg",
                           dwgName ))
        return;
    if (Acad::eOk != extDatabase.readDwgFile( dwgName ))
        acedAlert( "Error reading DWG!" );
        return;
 extDatabase.
    AcDbBlockTable* pBT;
    if (Acad::eOk != extDatabase.getSymbolTable( pBT, AcDb::kForRead ))
        acedAlert( "Error getting BlockTable of DWG" );
        return;
    AcDbBlockTableRecord* pBTR;
    Acad::ErrorStatus es = pBT->getAt( ACDB_MODEL_SPACE, pBTR, AcDb::kForRead );
    pBT->close();
    if (Acad::eOk != es) {
        acedAlert( "Error getting model space of DWG" );
        return;
    AcDbBlockTableRecordIterator* pIT;
    if (Acad::eOk != pBTR->newIterator( pIT )) {
        acedAlert( "Error iterating model space of DWG" );
        pBTR->close();
        return;
    for ( ; !pIT->done(); pIT->step()) {
        if (Acad::eOk == pIT->getEntityId( id )) {
            list.append( id );
            // There is a bug in ARX that causes extension dictionaries
            // to appear to be soft owners of their contents.  This causes
     // the contents to be skipped during wblock.  To fix this we
     // must explicitly tell the extension dictionary to be a hard
     // owner of it's entries.
            AcDbEntity *pEnt;
            if ( Acad::eOk == pIT->getEntity(pEnt, AcDb::kForRead)) {
                AcDbObjectId obj;
                if ((obj = pEnt->extensionDictionary())
                    != AcDbObjectId::kNull)
                    AcDbDictionary *pDict = NULL;
                    acdbOpenObject(pDict, obj, AcDb::kForWrite);
                    if (pDict) {
                        pDict->setTreatElementsAsHard(Adesk::kTrue);
                        pDict->close();
                pEnt->close();
    delete pIT;
    pBTR->close();
    if (list.isEmpty()) {
        acedAlert( "No entities found in model space of DWG" );
        return;
    AcDbDatabase *pTempDb;
    if (Acad::eOk != extDatabase.wblock( pTempDb, list, AcGePoint3d::kOrigin ))
        acedAlert( "wblock failed!" );
        return;
    if (Acad::eOk != acdbHostApplicationServices()->workingDatabase()
        ->insert( AcGeMatrix3d::kIdentity, pTempDb ))
        acedAlert( "insert failed!" );
    delete pTempDb;
GMT+8, 2025-5-25 12:13 , Processed in 0.155580 second(s), 23 queries , Gzip On.
