查看: 2195|回复: 1
autocad 2007 安装错误 求助
发表于 2006-11-22 16:14:00 | 显示全部楼层 |阅读模式
 AutoCAD 2007 安装错误
2006/11/22:13:28:02       XX  xx    === Installation started on xx by XX ===
2006/11/22:13:28:19       XX  xx    Install      MSI Runtime 3.1    Skipped   Windows Installer upgrade is not required. System Version = 3.1.4000.2435
2006/11/22:13:33:16       XX  XX  Install      .NET Framework Runtime 2.0      Succeeded        Command = "I:\Bin\AcadFEUI\support\dotnetfx\dotnetfx.exe" /q /c:"install /l /qb"
2006/11/22:13:34:06       XX  XX  Install      .NET Framework Runtime 2.0 Language Pack    Succeeded        Command = "I:\Bin\AcadFEUI\support\dotnetfx\chs\langpack.exe" /q:a /c:"install.exe /qb"
2006/11/22:13:34:34       XX  XX  Install      DirectX 9.0 Runtime      Succeeded        Command = "I:\Bin\AcadFEUI\support\DirectX\DXSETUP.exe" /silent
2006/11/22:13:34:35       XX  XX  Install      MDAC 2.7      Skipped   MDAC upgrade is not required. System Version = 2.81.1117.0
2006/11/22:13:35:13       XX  XX  Install      Autodesk DWF Viewer  Succeeded        Command = "I:\Bin\AcadFEUI\support\aev\DWFViewerSetup.exe" /u2 /q2 /b0
2006/11/22:13:35:21       XX  XX  Install      Flash       Failed      Failure is ignored, Result=1
2006/11/22:13:50:29       XX  XX  Install      AutoCAD 2007      Failed      Installation aborted, Result=1603
2006/11/22:13:50:29       XX  XX  === Installation ended ===
发表于 2006-11-23 22:33:00 | 显示全部楼层
什么系统?2korxp
GMT+8, 2025-5-23 10:06 , Processed in 0.179769 second(s), 29 queries , Gzip On.
