查看: 1340|回复: 1
求救!!!读取文件的一行后,无法对读取的字符串操作
发表于 2006-11-28 11:29:00 | 显示全部楼层 |阅读模式
(defun c:ofile()
  (setq file-path (findfile "bp.ini"))
  (setq point-f (open file-path "r"))
  (setq profile-list nil profile-table nil)
  (while (setq profile-list (read-line point-f))
   (setq stringlen (strlen profile-list))
   (setq num-test 1
  num-start nil
  char-len 0
  list-item nil
  new-profile-list nil)
   (while (<= num-test stringlen)
    (setq char-test (subst profile-list num-test 1))  ;运行到这行后就跳出,提示“命令: ofile ; 错误: 参数类型错误: consp 1,这是什么问题呀?
    (if (= char-test "space")
      (setq num-test (1+ num-test))
        (setq char-start num-test)
        (while (= char-test "space")
   (setq char-len (1+ char-len))
        (setq list-item (subst profile-list num-test char-len))
        (setq new-profile-list (append new-profile-list (list list-item)))
      );end progn
     );end if
    );end while
    (setq profile-table (append profile-table (list new-profile-list)))
发表于 2008-11-7 10:57:00 | 显示全部楼层
(setq char-test (subst profile-list num-test 1))  命令都是错的substr
GMT+8, 2025-9-21 14:34 , Processed in 0.192869 second(s), 26 queries , Gzip On.
