查看: 1497|回复: 1
求助一个关于选择集的问题
发表于 2006-11-29 15:31:00 | 显示全部楼层 |阅读模式
求助一个关于选择集的问题,有一张CAD画的表格,想提取里面的数据,如图
行与行之间是等距的,相差14.25,该文字在行之间,并未超过,参照帮助编了一个读取的程序,不知为何,老是不能正常读出来,有的读不出来,能读的,但是数值不对!请问给为高手可能的问题出现在什么地方:
Sub SelectTEXT()
    Dim i%
    Dim entity As AcadEntity
    Dim ssetObj As AcadSelectionSet
    For i = 1 To 32
    Set ssetObj = ThisDrawing.SelectionSets.Add("SS1")
    Dim mode As Integer
    Dim pointsArray(0 To 11) As Double
    Dim FilterType(3) As Integer
    Dim FilterData(3) As Variant
    mode = acSelectionSetFence
    pointsArray(0) = 1852.7125: pointsArray(1) = -90.3167 - 14.25 * (i - 1): pointsArray(2) = 0
    pointsArray(3) = 1926.9625: pointsArray(4) = -90.3167 - 14.25 * i: pointsArray(5) = 0
    pointsArray(6) = 1852.7125: pointsArray(7) = -90.3167 - 14.25 * i: pointsArray(8) = 0
    pointsArray(9) = 1926.9625: pointsArray(10) = -90.3167 - 14.25 * (i - 1): pointsArray(11) = 0
    FilterType(0) = -4
    FilterData(0) = "<or"
    FilterType(1) = 0
    FilterData(1) = "TEXT"
    FilterType(2) = 0
    FilterData(2) = "MTEXT"
    FilterType(3) = -4
    FilterData(3) = "or>"
    ssetObj.SelectByPolygon mode, pointsArray, FilterType, FilterData
    For Each entity In ssetObj
    Debug.Print entity.TextString
    Next
    ssetObj.Delete
    Next i
End Sub
发表于 2006-11-30 09:18:00 | 显示全部楼层
本人测试本段程序在CAD2004下结果正确,最好把你的图也传上来看看.
GMT+8, 2025-8-28 04:22 , Processed in 0.173781 second(s), 25 queries , Gzip On.
