(defun c:psc () (defun bpsc () (command "-xref" "r" "*") (command "-xref" "b" "*") (command "-purge" "a" "*" "n") (command "qsave") (command "close") ) (princ (bpsc)) (vl-load-com) (setq docs (vla-get-Documents (vlax-get-acad-object)) ) (vlax-for cendoc docs (vla-bpsc cendoc) ) ) (princ)
目的是想在所有已打开的图纸中执行bpsc的功能,可是不好使,能否为在下调试一下        |
