查看: 1444|回复: 0
运行起来无错误,但就是初始化窗体时不显示块属性?
发表于 2006-12-3 02:39:00 | 显示全部楼层 |阅读模式
Private Sub UserForm_Initialize()
  '根据AutoCAD的版本来确定使用ObjectDBX的版本
      If Left(Version, 2) = "15" Then
          Set objDbx = CreateObject("ObjectDBX.AxDbDocument.1")
      ElseIf Left(Version, 2) = "16" Then
          Set objDbx = CreateObject("ObjectDBX.AxDbDocument.16")
      End If
  '判断图中是否有TitleTable模块,若有则读取图块的信息;否则初始化为缺省值。
      Dim objBlkref As AcadBlockReference
      Dim objEnt As AcadEntity
      Dim VarAttributes As Variant
      Dim i As Integer
      On Error Resume Next
      For Each objEnt In ThisDrawing.Blocks
          '取得块属性
          If StrComp(objEnt.Name, "TitleTable") = 1 Then
          Set objBlkref = objEnt
          VarAttributes = objBlkref.GetAttributes
          For i = LBound(VarAttributes) To UBound(VarAttributes)
          If UCase(VarAttributes(i).TagString) = "模块代号01" Then txtbox1.Text = VarAttributes(i).TextString
          If UCase(VarAttributes(i).TagString) = "模块代号02" Then txtbox2.Text = VarAttributes(i).TextString
          Next i
          Else
          ThisDrawing.Utility.Prompt vbCr & "图中没有标题栏."
          txtbox1.Text = "1"
          txtbox2.Text = "2"
          End If
      Next objEnt
End Sub
其中,txtbox1,txtbox2是窗体上的两个txtbox控件。CAD中已经存在TitleTable属性块,但是运行该代码后,对话框窗体上这两个控件却空空如也,甚至"1","2"都没有。请高手指点一下,谢谢!!!
GMT+8, 2025-8-28 04:20 , Processed in 0.153621 second(s), 24 queries , Gzip On.
