查看: 1780|回复: 1
[LISP]:[编程申请]:求助]:除了ctrl+1,可以一键打开和关闭特性对话框吗?
发表于 2006-12-4 15:06:00 | 显示全部楼层 |阅读模式
(defun c:ttest (/ tt apple_sel apple_nnblk)
(vl-load-com)
  (setq tt t)
   (while tt
     (setvar "errno" 0)
     (setq apple_sel (entsel "\n选择要改为匿名块的图块: ")
     (if (/= (getvar "errno") 7)
      (setq tt nil)
(setq apple_nnblk (vlax-ename->vla-object(car apple_sel)))
(if (= (vla-get-objectname apple_nnblk) "AcDbBlockReference")
    (vla-put-name
      (vla-item (vla-get-blocks
       (vla-get-activedocument (vlax-get-acad-object))
(vla-get-name apple_nnblk)
"*U"
  (princ "\n######---选择物体非块---######")
发表于 2006-12-4 21:32:00 | 显示全部楼层
(defun c:VC()
(if (= jilujilu nil)
(setq jilujilu 1)
(if (= (rem jilujilu 2) 0)
(command "properties")
(command "propertiesclose")
(setq jilujilu (+ 1 jilujilu ))
GMT+8, 2025-11-23 13:05 , Processed in 0.204729 second(s), 25 queries , Gzip On.
