查看: 2121|回复: 2
vba怎样获得 特性 面板上的面积值?
发表于 2006-12-13 14:59:00 | 显示全部楼层 |阅读模式
如题:
用多段线或样条曲线等做的不封闭区域也有
面积 ,在 特性
面板上有显示。
用怎样的VBA获取??
请高手赐教!
发表于 2006-12-14 11:45:00 | 显示全部楼层
多义线的属性里有一个面积的值啊
Sub Example_Area()
    ' This example creates a polyline object and
    ' then uses the area property to find the
    ' area of that polyline.
    Dim plineObj As AcadLWPolyline
    Dim points(0 To 5) As Double
    Dim plineArea As Double
    ' Establish the points for the Polyline
    points(0) = 3: points(1) = 7
    points(2) = 9: points(3) = 2
    points(4) = 3: points(5) = 5
    ' Create the polyline in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ' Close the polyline and update display of it
    plineObj.Closed = True
    plineObj.Update
    ZoomAll
    ' Get the area of the polyline
    plineArea = plineObj.Area
    MsgBox "The area of the new Polyline is: " & plineArea, vbInformation, "Area Example"
End Sub
 楼主| 发表于 2006-12-15 13:21:00 | 显示全部楼层
多谢多谢,终于知道了。
GMT+8, 2025-12-1 04:08 , Processed in 0.120525 second(s), 23 queries , Gzip On.
