查看: 1728|回复: 1
多段线??
发表于 2006-12-15 18:32:00 | 显示全部楼层 |阅读模式
  1. 我想用多段线做一关系曲线(库容曲线)怎么样做个循环?不必要像这样
  2. points(0) =xlsheet.cells(8, 8).Value: points(1) =xlsheet.cells(8, 1).Value
  3. points(2) =xlsheet.cells(9, 8).Value: points(3) =xlsheet.cells(9, 1).Value
  4. points(4) =xlsheet.cells(10, 8).Value: points(5) =xlsheet.cells(10, 1).Value
  5. points(6) =xlsheet.cells(11, 8).Value: points(7) =xlsheet.cells(11, 1).Value
  6. points(8) =xlsheet.cells(12, 8).Value: points(9) =xlsheet.cells(12, 1).Value
  7. points(10) =xlsheet.cells(13, 8).Value: points(11) =xlsheet.cells(13, 1).Value
  8. points(12) =xlsheet.cells(14, 8).Value: points(13) =xlsheet.cells(14, 1).Value
  9. points(14) =xlsheet.cells(15, 8).Value: points(15) =xlsheet.cells(15, 1).Value
  10. points(16) =xlsheet.cells(16, 8).Value: points(17) =xlsheet.cells(16, 1).Value
  11. points(18) =xlsheet.cells(17, 8).Value: points(19) =xlsheet.cells(17, 1).Value
  12. points(20) =xlsheet.cells(18, 8).Value: points(21) =xlsheet.cells(18, 1).Value
  13. points(22) =xlsheet.cells(19, 8).Value: points(23) =xlsheet.cells(19, 1).Value
  14. points(24) =xlsheet.cells(20, 8).Value: points(25) =xlsheet.cells(20, 1).Value
  15. points(26) =xlsheet.cells(21, 8).Value: points(27) =xlsheet.cells(21, 1).Value
  16. points(28) =xlsheet.cells(22, 8).Value: points(29) =xlsheet.cells(22, 1).Value
  17. points(30) =xlsheet.cells(23, 8).Value: points(31) =xlsheet.cells(23, 1).Value
  18. points(32) =xlsheet.cells(24, 8).Value: points(33) =xlsheet.cells(24, 1).Value
  19. points(34)=xlsheet.cells(25, 8).Value: points(35)=xlsheet.cells(25, 1).Value
  20. points(36)=xlsheet.cells(26, 8).Value: points(37)=xlsheet.cells(26, 1).Value
  21. points(38)=xlsheet.cells(27, 8).Value: points(39)=xlsheet.cells(27, 1).Value
  22. points(40)=xlsheet.cells(28, 8).Value: points(41)=xlsheet.cells(28, 1).Value
复制代码
发表于 2006-12-18 10:09:00 | 显示全部楼层
sa3226390发表于2006-12-15 18:32:00我想用多段线做一关系曲线(库容曲线)怎么样做个循环?不必要像这样points(0) =xlsheet.cells(8, 8).Value: points(1) =xlsheet.cells(8, 1).Valuepoints(2) =xlsheet.cells(9, 8).Value: poi
FOR I=0 TO 40 STEP2
POINTS(I)=XLSHEET.CELLS(I+8,8)..........
NEXT I
GMT+8, 2025-12-1 04:09 , Processed in 0.122542 second(s), 23 queries , Gzip On.
