查看: 2023|回复: 8
[求助]enmake建立多段线的问题
发表于 2006-12-16 21:24:00 | 显示全部楼层 |阅读模式
用lisp写了一个小程序,从文本文件读入坐标,在cad里画多段线,文本格式为:
1 495227 4143786
1 495226 4143788
1 495225 4143790
程序源码如下:
(defun c:tkl (/ filename pointgroup corlist data POINTNUMBER)
  (setq filename (open (getfiled "选择数据文件" " " "" 0) "r"))
  (setq pointgroup
      nil
 OINTNUMBER 0
  (while (sETQ DATA (read-line filename))
    (setq corlist (list (list 10
         (CAdR (READ (STRCAT "(" DATA ")")))
         (CAddR (READ (STRCAT "(" DATA ")")))
   (cons 40 0)
   (cons 41 0)
   (cons 42 0)
    (setq pointgroup (append corlist pointgroup))
    (SETQ POINTNUMBER
    (1+ POINTNUMBER)
     ;(setq pointgroup (reverse pointgroup))
  (print pointgroup)
  (close filename)
  (entmake
    (list (append
     (list
       (cons 0 "LWPOLYLINE")
       (CONS 5 "150")
       (cons 100 "AcDbEntity")
       (CONS 67 0)
       (cons 410 "model")
       (cons 8 "tracklines")
       (cons 100 "AcDbPolyline")
       (cons 90 POINTNUMBER)
       (cons 70 0)
       (cons 43 0)
       (cons 38 0)
       (cons 39 0)
     pointgroup
    (LIST (list 210 0.0 0.0 1))
  (gc)
运行后提示:
错误: DXF
组不正确: ((0 . "LWPOLYLINE") (5 . "150") (100 . "AcDbEntity") (67 . 0) (410 .
"model") (8 . "tracklines") (100 . "AcDbPolyline") (90 . 3) (70 . 0) (43 . 0)
(38 . 0) (39 . 0) (10 495225 4143790) (40 . 0) (41 . 0) (42 . 0) (10 495226
4143788) (40 . 0) (41 . 0) (42 . 0) (10 495227 4143786) (40 . 0) (41 . 0) (42 .
0) (210 0.0 0.0 1))
请高手指点,错在何处了,不胜感激。
发表于 2006-12-16 21:55:00 | 显示全部楼层
我觉得最好用vlisp写,这样省得记繁杂的dxf组码!
 楼主| 发表于 2006-12-16 22:14:00 | 显示全部楼层
vlisp不熟呢,否则也用不着这么麻烦。
发表于 2006-12-16 22:26:00 | 显示全部楼层
找本资料好好研究一下!
发表于 2006-12-18 17:23:00 | 显示全部楼层
如果图省事,直接用command函数,调用AUTOCAD的pline命令.程序十分明了.
当然显得不是十分专业.
发表于 2006-12-18 19:59:00 | 显示全部楼层
这个问题好象在哪儿见过,版主已经给了你很好的答复!
发表于 2006-12-19 08:15:00 | 显示全部楼层
  1. ;;表錯了!
  2. (entmake
  3.     (append
  4.       (list
  5. (cons 0 "LWPOLYLINE")
  6. (cons 100 "AcDbEntity")
  7. (cons 410 "model")
  8. (cons 8 "tracklines")
  9. (cons 100 "AcDbPolyline")
  10. (cons 90 POINTNUMBER)
  11. (cons 70 0)
  12.       )
  13.       POINTGROUP
  14.       (list (list 210 0.0 0.0 1))
  15.     )
  16.   )
复制代码
发表于 2006-12-24 23:44:00 | 显示全部楼层
(CONS 5 "150")
这一句有问题,DXF组码为5的是实体的句柄,是由CAD自动生成的,做为对实体在图形的唯一索引,相当于数据库中的自动编号的ID号,在使用entmake语句时不能定义实体的句柄
发表于 2020-2-16 14:33:34 | 显示全部楼层
组码错了,修改一下就得了
GMT+8, 2025-6-28 06:18 , Processed in 0.275963 second(s), 25 queries , Gzip On.
