查看: 1502|回复: 2
那位大哥能帮我看一下这个程序问题出在那吗.谢谢
发表于 2006-12-16 22:51:00 | 显示全部楼层 |阅读模式
(defun c:loo( / a b c d1 e PT pt1 PTT pt2 pt3 lst1 d2 d3 lst2 lst3 LN laynmlst NL OL e1 e2 e3)
  ;(init_bonus_error
  ;(list
  ;      (list "cmdecho" 0
  ;      "expert" 0
  ;T
  ;)(setvar "osmode" 0)
           (setq pt1 (getpoint "\nSelect First Corner Point:"))
           (setq pt (getCORNER PT1 "\nSelect Second Corner Point:"))
           (setq pt2 (getpoint "\nEnter The Ready place Point:"))
           (setq a (ssget "C" PT PT1))
          (LAYERLIST)(SETQ NL NIL OL NIL)
          (FOREACH LN laynmlst (IF (= (STRLEN LN) 4)(SETQ NL(CONS LN NL))))
          (SETQ laynmlst NL)(setq lst1 NIL)(setq lst2 NIL)(setq lst3 NIL)
          (FOREACH LN laynmlst (SETQ LN (SUBSTR LN 1 4))(IF (/=OL LN)(PROGN(SETQ OL LN)(IF (= (SUBSTR LN 1 1) "D")(SETQ lst1(CONS LN lst1))))))
   (FOREACH LN laynmlst (SETQ LN (SUBSTR LN 1 4))(IF (/= OL LN)(PROGN(SETQ OL LN)(IF (= (SUBSTR LN 1 1) "P")(SETQ lst2(CONS LN lst2))))))
   (FOREACH LN laynmlst (SETQ LN (SUBSTR LN 1 4))(IF (/= OL LN)(PROGN(SETQ OL LN)(IF (= (SUBSTR LN 1 1) "S")(SETQ lst3(CONS LN lst3))))))
   (setq e1 0)
    (setq e2 0)
    (setq e3 0)
    (setq d1 0)
    (setq d2 0)
    (setq d3 0)
    (IF lst1(while (( d1 (LENGTH lst1))
       (setq c (nth d1 lst1))
       (command "layer" "lock" "*" "")
       (SETQ C (STRCAT C "*"))
       (command "layer" "unlock" c "")
       (setq pt3 (list (+  (car pt2)(* (DISTANCE PT PT1) e1) ) (cadr pt2)))
       (command "copy" a "" pt1 pt3)
       (SETQ PTT(POLAR PT3  (/ PI 2.7) (/ (DISTANCE PT PT1)1.5) ))
       (COMMAND "TEXT" "J" "BL" PTT "200 "0" (nth d1 lst1))
         (setq d1 (+ d1 1))
         (setq e1 (+ e1 1))
      (IF lst2(while (( d2 (LENGTH lst2))
              (setq c (nth d2 lst2))
              (setq pt3 (list (+ (car pt2)(* (DISTANCE PT PT1) e2 ) )(+ (cadr pt2) (*(DISTANCE PT PT1)2))))
              (COMMAND "TEXT" "J" "BL" PTT "200" "0" (nth d2 lst2))
                (setq d2 (+ d2 1))
                (setq e2 (+ e2 1))
             (IF lst3(while (( d3 (LENGTH lst3))
             (setq c (nth d3 lst3))
             (setq pt3 (list(+(car pt2)(* (DISTANCE PT PT1) e3) )  (+ (cadr pt2) (DISTANCE PT PT1))))
             (COMMAND "TEXT" "J" "BL" PTT "200" "0" (nth d3 lst3))
             (setq d3 (+ d3 1))
             (setq e3 (+ e3 1))
             (command "layer" "unlock" "*" "")
        ;  (restore_old_error)
            (setvar "osmode" 39)
            (defun LAYERLIST (/ layname sortlist name templist layer_number)
            (setq sortlist nil)
            (setq templist (tblnext "LAYER" T))
            (while templist
            (if (/= (logand 16 (cdr (assoc 70 templist))) 16)
            (setq name (cdr (assoc 2 templist)))
             (setq sortlist (cons name sortlist))
            (setq templist (tblnext "LAYER"))
            (if ()= (getvar "maxsort") (length sortlist))
            (setq sortlist (acad_strlsort sortlist))
            (setq sortlist (reverse sortlist))
            (setq laynmlst sortlist)
            (PRINC "\n\t Press LO to layout the plate!")?
发表于 2006-12-18 12:09:00 | 显示全部楼层
程序是书上抄的吧。
1、所有WHILE后面的双左括弧均改成:(<
2、删去末尾的问号
发表于 2006-12-18 16:48:00 | 显示全部楼层
本程序不能加载的原因十有八九是括号左右不匹配.
建议采用缩行格式排版,然后在检查括好的匹配.等程序能成功加载了,再检查内部错误.
GMT+8, 2025-9-19 03:57 , Processed in 0.393597 second(s), 27 queries , Gzip On.
