查看: 2658|回复: 3
如何得到模型空间当前视图的最大坐标和最小坐标
发表于 2006-12-21 10:55:00 | 显示全部楼层 |阅读模式
也就是左下角点和右上角点坐标。
viewctr只能得到中心坐标,viewsize只能得到高度。如何得到宽度?
发表于 2006-12-21 11:57:00 | 显示全部楼层
AutoLISP FAQ (part 2/2) - samples, code
[21.7] Select all visible objects: zoom coordinates
  Beware that with (ssget) you will only get visible objects, because
  all interface functions (entsel,ssget,osnap) work with pixel, only
  (ssget "X") will select not visible objects.
  ;;; returns a list of the actual viewport corners in WCS
  (defun ZOOMPTS ( / ctr h screen ratio size size_2)
    (setq ctr (xy-of (getvar "VIEWCTR")) ;3D -> 2D
          h   (getvar "VIEWSIZE")        ;real
          screen (getvar "SCREENSIZE")   ;2D: Pixel x,y
          ratio (/ (float (car screen))  ;aspect ratio
                   (cadr screen))
          size (list (* h ratio) h)      ;screensize in coords
          size_2 (mapcar '/ size '(2.0 2.0)))
      (list (mapcar '- ctr size_2)
            (mapcar '+ ctr size_2)))
发表于 2006-12-21 12:39:00 | 显示全部楼层
vxmax和vxmin
发表于 2023-4-24 13:12:31 | 显示全部楼层
用到了谢谢,分享
GMT+8, 2025-5-15 00:26 , Processed in 0.175573 second(s), 26 queries , Gzip On.
