查看: 3323|回复: 9
请帮忙解决用autolisp读取txt文件问题
发表于 2006-12-22 18:21:00 | 显示全部楼层 |阅读模式
请专家帮忙:
我在试图用autolisp读取txt文件中的数据,程序如下:
(defun c:zdm()
(setq f  (open "d:\ct-aaa.txt" "r"))
(setq hantxt (read-line))
(print yhantxt)
  (close f)
d:\ct-aaa.txt的内容如下:
25223562, 47547477,
545747,  5
可是好像什么都读不出来,死循环,要敲回车键才能退出。
各位高手能否指点迷津?
发表于 2006-12-22 20:29:00 | 显示全部楼层
(defun c:zdm(/ str list1)
(setq f  (open "d:\\ct-aaa.txt" "r");注意此处有错
 str(read-line a)
 list1 nil
(while str
  (setq list1 (append list1 (list str))
str(read-line f)
  (close f)
list1
(princ (c:zdm))
试试这个。
发表于 2006-12-23 16:19:00 | 显示全部楼层
(defun c:zdm()
  (setq f  (open "d:/ct-aaa.txt" "r"))
  (print hantxt)
  (close f)
发表于 2006-12-27 20:14:00 | 显示全部楼层
您看:下面的程序产生的txt文件,第一列代表节点号,第一列代表坐标X值,第一列代表坐标Y.
T1.txt
T1         493364.659    331110.429
T2         493381.852    331052.463
T3     493524.444    331099.020
我想画pline线并标节点号,
怎么读完是下面这样啊:
 ("T1  \t493364.659 \t331110.429" "T2  \t493381.852 \t331052.463" "T3 \t493524.444 \t331099.020")
对于这样的结果是不能用的吧。
我能变成下面的文件就好用了
请问各大侠:我怎么编程啊;我用read函数后,\t493364.659会变为493364.0,小数点后4舍5入了,好郁闷啊?
发表于 2006-12-27 21:48:00 | 显示全部楼层
加上这一句
(setq hantxt (read (strcat "(" (read-line) ")")))
发表于 2006-12-28 10:58:00 | 显示全部楼层
  1. (DEFUN C:TEST ()
  2. (SETVAR "CMDECHO" 0)
  3. (IF (SETQ F (OPEN "D:/T-AAA.TXT" "r")) (PROGN
  4.   (SETQ LST (LIST (READ (STRCAT "(" (SUBSTR (READ-LINE F) 2) ")"))))
  5.   (WHILE (SETQ STR (READ-LINE F))
  6.    (SETQ LST (APPEND LST (LIST (READ (STRCAT "(" (SUBSTR STR 2) ")"))))
  7.   )
  8.   (CLOSE F)
  9.   (SETQ I 0)
  10.   (SETQ PT (CDAR LST))
  11.   (COMMAND "PLINE" PT)
  12.   (REPEAT (LENGTH LST)
  13.    (SETQ PT (CDR (NTH (SETQ I (1+ I)) LST))
  14.    (COMMAND PT)
  15.   )
  16.   (COMMAND "")
  17.   (SETQ I -1)
  18.   (REPEAT (LENGTH LST)
  19.    (SETQ PS (NTH (SETQ I (1+ I)) LST)
  20.          PN (STRCAT "T" (CAR PS))
  21.          PT (CDR PS))
  22.    (COMMAND "TEXT" PT "" "" PN)
  23.   )
  24. ))
  25. (SETVAR "CMDECHO" 1)
  26. (PRINC)
  27. )
复制代码
发表于 2006-12-28 16:10:00 | 显示全部楼层
楼上ZZXXQQ版主,您好
我怎么运行程序后,总提示有错"错误: 输入的列表有缺陷"
另外,"read"函数不能随便用,比如(read "(493364.659 331110.429  )"),运行后为(493365.0 331110.0).
read函数,受lisp限制,数据被四舍五入了,所以是不能用的.
用下面的程序,能把txt数据,按行加括号
(setq f (getfiled "选择一个文件" "" "" 8))
          (setq f(findfile f))
          (SetQ  fn (Open f "r") )
          (SetQ  fnn (Open "asasw" "w") )
(While (SetQ a1 (Read-Line fn))
   (setq fila (strcat "(" a1 ")"  ) )
    (SetQ  fnnn (write-line fila  fnn )) ;
  (Close fn)
(Close fnn)
功能:
T1.txt
变成下面的文件就好用了
发表于 2006-12-28 16:32:00 | 显示全部楼层
用autolisp读取txt文件问题,实际上有好多方法,上面只是其中一种,最终还要根据txt文件的结构来确定.
最主要函数是字符串的转换.对任何txt文件,合理利用下面函数的搭配,就能解决lisp读txt问题
(vl-string-trim " " aa)
(ascii "(")
(ascii ")")
(ascii ".")
(chr 9)
(vl-string-search " " a1)
(write-char 67 f)
(setq a1w(vl-string->list  fila))
(SetQ  fnn (Open "asas" "w") )
(foreach a  a1w
  (progn  (write-char a  fnn)
发表于 2006-12-28 16:49:00 | 显示全部楼层
还有一个例子,(转贴)
(这是一个有关DMC配准前读txt中(见附件)的特定字符串后坐标的小程序,例子中我只提取西南和东北角点的X,Y坐标)
(defun c:DMCpz ( / txt fi start li str_tfh str_blc
  str_WSx str_WSy str_ENx str_ENy WS_x WS_y EN_x EN_y
   (setq path_txt (getfiled "Select .txt file" "" "txt" 2))
   (setq fi (open path_txt "r"))
   (setq ;str_tfh ""
 str_WSx ""
 str_WSy ""
 str_ENx ""
 str_ENy ""
 ;str_blc "1:5000"
  (setq start T)
  (while (and start (setq li (read-line fi)))
    (cond
      ((wcmatch li "*图号*") (setq str_tfh li))
      ((wcmatch li "*DOM裁切范围西南角点X坐标*") (setq str_WSx li))
      ((wcmatch li "*DOM裁切范围西南角点Y坐标*") (setq str_WSy li))
      ((wcmatch li "*DOM裁切范围东北角点X坐标*") (setq str_ENx li))
      ((wcmatch li "*DOM裁切范围东北角点Y坐标*") (setq str_ENy li)(setq start nil))
      (t nil)
    (setq WS_x
      (atof (substr str_WSx (+ 1 (strlen ":") (vl-string-search ":" str_WSx)))
    (setq WS_y
      (atof (substr str_WSy (+ 1 (strlen ":") (vl-string-search ":" str_WSy)))
    (setq EN_x
      (atof (substr str_ENx (+ 1 (strlen ":") (vl-string-search ":" str_ENx)))
    (setq EN_y
      (atof (substr str_ENy (+ 1 (strlen ":") (vl-string-search ":" str_ENy)))
     (command ".line" (list WS_x WS_y) (list EN_x EN_y) "")
    (close fi)
发表于 2006-12-30 08:40:00 | 显示全部楼层
太忙,程序未调试。下面是调试好的程序:
  1. (DEFUN C:TEST ()
  6.    (SETQ LST (APPEND LST (LIST (READ (STRCAT "(" (SUBSTR STR 2) ")")))))
  7.   )
  8.   (CLOSE F)
  9.   (SETQ I 0)
  13.    (SETQ PT (CDR (NTH (SETQ I (1+ I)) LST)))
  14.    (COMMAND PT)
  15.   )
  16.   (COMMAND "")
  17.   (SETQ I -1)
  20.   PN (STRCAT "T" (ITOA (CAR PS)))
  21.   PT (CDR PS))
  22.    (COMMAND "TEXT" PT 10 "" PN)
  23.   )
  24. ))
  26. (PRINC)
  27. )
复制代码
GMT+8, 2025-11-23 11:35 , Processed in 0.286844 second(s), 26 queries , Gzip On.
