查看: 1874|回复: 0
move+copy+rotate+scale
发表于 2006-12-22 21:40:00 | 显示全部楼层 |阅读模式
(defun C:MR( / ssg p1 p2 YN sc)
(if (setq ssg (ssget))
     (setvar "cmdecho" 0)
        (setq p1 (getpoint "\n指定基点:")
              p2 (getpoint p1 "\n指定第二个点:")
        (setq YN (strcase (getstring "\n是否保留原对象?[Y/N]<Y>:" )))
        (if (= YN "") (setq YN "Y"))
 (command "move" ssg "" p1 p2)
        (if (= YN "Y") (command "copy" ssg "" p2 p1))
        (princ "\n指定旋转角度:")
        (command "rotate" ssg "" p2 pause)
        (setq sc (getdist p2 "\n指定缩放比例 <1>:"))
        (if (= sc "") (setq YN "1"))
        (command "scale" ssg "" p2 sc )
mccad + 1 【好评】表扬一下
GMT+8, 2025-9-19 03:56 , Processed in 0.246631 second(s), 30 queries , Gzip On.
